RX-8 @ dealership part 2
Old Apr 26, 2005 | 04:23 PM
cgrx's Avatar
DRIVEN
Damn, this is the 4th time my A/C has been outta wack and in for replacement.
It will be blowing cold and then randomly get hot. I have to turn the **** back and forth and then it will get cold again. They are also replacing the drivers side center console trim because they scratched it when re-lubing my squeaky seats.
At least I got the 6MT GT red RX-8 again
Old Apr 26, 2005 | 05:10 PM
Glyphon's Avatar
脾臓が痛みました
what is it with you people breaking your ACs? :p
Old Apr 26, 2005 | 05:39 PM
cgrx's Avatar
DRIVEN
I'd like to blame MAZDA
also - this stock RX8 feels a bit faster/more responsive than mine.........I have a Borla catback at this time
Old Apr 26, 2005 | 06:08 PM
cgrx's Avatar
DRIVEN
Very annoying ! Make them replace it.
I only have about 7k miles on my warranty too..........
Old Apr 27, 2005 | 09:18 AM
fray's Avatar
My AC seems to work fine. However, the temp control itself doesn't work worth a crap.
What happens is I have to turn it all the way hot/cold to get any temp change.. or set it where I want and "tap" the switch. Of course some times if I hit a bump then it goes back to the last "extreme".
Of course the dealer was unable to replicate. My plan is to keep harping on them till they do something. In my case, I suspect the switch is just bad. Should be easy for them to fix......
Old Apr 27, 2005 | 03:06 PM
cgrx's Avatar
DRIVEN
mine does that too
Old Apr 27, 2005 | 06:45 PM
cgrx's Avatar
DRIVEN
I have the car till Monday. SWEET
I'll post on how the fixed the A/C problem............
Old Apr 27, 2005 | 07:19 PM
snap-on's Avatar
AC NOT COOL (AFTER 9/11/03 PRODUCTION)
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 40118171 ********
Some customers may complain of lack of AC cooling from the vents. This may be caused by the intake air selector (recirculate / fresh) in the "FRESH" mode. Cooling the interior of the vehicle may take longerif the air intake selector is in the "FRESH" mode. Maximum cooling is acheived when the intake air selector mode is in the "RECIRC" position. The AC amplifier can be programmed to automatically default to "RECIRC" mode when the following conditions are met: 1. Ambient air temperature is 68 deg. F or higher. 2. HVAC control mode is in "FACE" mode. 3. HVAC temperature is in maximum cool setting. Customers with this concern should have their vehicle repaired using the repair procedure. NOTE: Vehicles produced before 9/11/2003 are not programmable N should have the AC amp replaced per Service Bulletin # 07-002/04 1. Verify concern. 2. Verify ignition switch is in OFF position. 3. Press and hold the front defrost and air intake selector buttons simultaneously. 4. Turn the ignition key to the "ACCY" position for 3 seconds. (Continue to hold the buttons down from step #3.) 5. Turn the ignition key to the "ON" position for 3 seconds. (Continue to hold the buttons down from step #4.) 6. Successful programming will be confirmed by the rear defrost indicator light flashing 3 times. NOTE: If vehicle's battery dies or cables are removed, the programming will not be retained and must be performed again.
Old Apr 27, 2005 | 07:31 PM
Glyphon's Avatar
脾臓が痛みました
i might have to try that. i find it kinda annoying having to switch back to recirc everytime after i change the "mode" (direction a better word?) of the hvac.
Old Apr 27, 2005 | 09:04 PM
cgrx's Avatar
DRIVEN
I'm not mad. I get the loaner 8 for my drive down to SoCal. Saves me 1000 miles on my own 8...
Old Apr 27, 2005 | 09:38 PM
joseight's Avatar
n00b
you got an rx-8 loaner?!?! wtf, i got a base trim mazda6 when i took mine in. BS
Old Apr 27, 2005 | 10:37 PM
cgrx's Avatar
DRIVEN
I miss the nav though...........
Old Apr 27, 2005 | 11:03 PM
snap-on's Avatar
As I recall you have a constant CEL from exhaust mods?
Are you disconnecting the battery to reset?
Old Apr 27, 2005 | 11:05 PM
cgrx's Avatar
DRIVEN
I sold the B&B midpipe a month or so ago. No CEL now.
Old Apr 27, 2005 | 11:23 PM
snap-on's Avatar
I hope your local dealer can find the MRI I posted. You might want to ask them if they have searched the ESI site for your issue.
But you didn't hear it from me...
IamFodi
Aug 11, 2015 01:51 PM
