My RX8 is sick ??!
Old Apr 13, 2005 | 07:29 PM
Danielson's Avatar
My RX8 is sick ??!
I didn't start my RX8 for about 3 or 4 days, this afternoon I wanted to go for a little ride but the car never wanted to start !!!!
I drove my RX8 all winter long without any trouble, now by a beautiful day and without any warning what so EVER ...The car didn't start at all !!!
That's how it left home this afternoon....on a towing truck !
P.S And it isn't the battery ...So don't ask ....
Attached Thumbnails My RX8 is sick ??!-sick-1.jpg   My RX8 is sick ??!-sick.jpg
Old Apr 13, 2005 | 07:32 PM
BlueFrenzy's Avatar
Rotary Powered Decepticon
Sorry to hear that right after you just got clears. I'm sure you tried the emergency start and all with no luck. Didn't by chance started it and then turned it off, did you?
Hope it works out for you.
Old Apr 13, 2005 | 07:38 PM
Sajek's Avatar
I think its punishing you for not driving it for 4 days. :o
Old Apr 13, 2005 | 08:21 PM
Danielson's Avatar
I guess BlueFrenzy is right again...I did start it and move it a few feet and then turned it off, I really didn't think it would effect the engine that bad ??
Hope to hear from my dealer by tomorrow, they were already talking about changing a part of my starter..IE like a recall on it or something like that ?
I am very busy at work and Off work too... I have no time to drive it :o
Old Apr 13, 2005 | 09:17 PM
Danielson's Avatar
Well, well, My dealer was closing at 1700 today, They called me at home at 1830 to let me know that my Baby is O.K !!!
What a good service !! :D too bad I am working until tomorrow morning...
I will let you know what went wrong tomorrow...and my Baby don't have any reason to do this to me...I take very good care of it all the time, my RX8 look like a brand new one's with 33000km on it
Old Apr 13, 2005 | 09:28 PM
BlueFrenzy's Avatar
That's great to hear that your 8 is ok. I guess from now on you'll be revving to 3000 before shutting it down!
Old Apr 13, 2005 | 09:30 PM
Sea Ray's Avatar
What do you think went wrong? Did you even read the manual and remember what it said? They say to warm the car up for a reason, and you now know first hand just what the reason is. Bet you wont do that again.
Keep an eye on your cat, they can go bad after a flood.
Old Apr 13, 2005 | 09:41 PM
Danielson's Avatar
What do you mean by "go bad !"
Old Apr 13, 2005 | 10:20 PM
Sea Ray's Avatar
When you flood the car, where do you think a lot of the excess fuel goes? Into the catalytic converter, my local dealer has had to replace several and they all had been flooded at some point.
Not sure exactly what happens but it bascially falls apart, probably from the heat, and then clogs up the exhaust. This kind of restriction will degrade performance.
Old Apr 13, 2005 | 10:46 PM
Neo's Avatar
Neo
I am The One!
Danielson,
Sucks to hear... But it sounds like you got hit by the "not warmed up" bug... What flash version are you running??
I don't see any RX-8's having this type of problem around my area... and I personally have to move my 7 a few feet up and down the driveway... still fires up without a problem... I don't see why the 8 will be any different...
I could always ask MyRxBad about his....
And yes, eventually the cats will go bad on a rotary... faster than a piston counterpart... that's just a part of life... letting the exhaust flow freely should increase output... but not by a whole lot...
Don't worry Danielson... next time you'll know what to do...
Lates,
Old Apr 13, 2005 | 11:24 PM
Danielson's Avatar
Thanks for the info sea ray, I will see into it... I learn my lesson.
My Baby run with the new N flash, just did it this winter (was supposed to help the car to start easier ), which I never had any trouble anyway... Hope this won't affect in any way the performance of my RX8
Old Apr 14, 2005 | 08:14 AM
Quinte 8's Avatar
Danielsan; Real sorry to hear that your 8 had a rough day. Glad all is well!! Hope it might make you feel any better to know that we've flooded the RX7 many times. The 7 actually has a kill switch to clear the fuel. She still runs great.
:D As a matter of fact there are several pictures of our beloved RX7 leading the pack it in Belleville :D
Old Apr 14, 2005 | 10:09 AM
MyRxBad's Avatar
Fb's rock!
Yeah after a flood, if brought to the dealer, they have to do a road test to check the cat via the on board computer (after the road test at certain rpm for certain time) to see if it's still in spec. The cat "gone bad" doesn't mean that it's not any good/working anymore, it's just not up to the 2004 specs they built it to and now with the tougher regulations on new cars, the cat has to last for 7 years or 120k (under warrenty), so....
I'm surprized she flooded out on you w/the "N" flash, but a rotary is a rotary and she doesn't like the cold. I just got the "N" flash yesterday, but I never had a problem w/cold starting the car (but it still isn't my normal practice to do so.)
Old Apr 14, 2005 | 10:40 AM
Quinte 8's Avatar
When I first got my 8 I didn't realize it was down and over for reverse. I stalled her twice cause I was in 6th. Real cold morning at 7am! I thought I was toast. But she fired right back up..both times. Guess I was just lucky.
Tricia (wife of quinte, mom of Quick) has flooded her but she got her started by pressing the peddle to the metal. We explained that you never touch the gas when starting. No problems since. :D
Old Apr 14, 2005 | 08:51 PM
Danielson's Avatar
Update
Well, I got my RX8 back this morning, they changed all 4 spark plugs with the new one's, 2 x different kinds (that's new to improve combustion) everyone should get this done on their car and also I have a new starter coming my way (faster one) this is a improvement by Mazda Canada, unfortunaly they are back order
and Yes they also changed the oil but not the filter ??
I raised my hat to the dealer at Belleville for the fast service, they also worked on my car after the business hour for one hour and half...
THANK EVERYONE FOR CARING FOR ME...WE ARE ALL FAMILY
Old Apr 15, 2005 | 06:14 AM
RX4life's Avatar
any time you want to "on-off" the car give it a good rev to atleast 4-5K and shut it off.. when the engine is cold...on the other hand when the car is warmed up just rev to 3k..i always rev it to 3k whenever shutting the engine off after a drive..peace of mind.
Old Apr 15, 2005 | 08:03 AM
Quinte 8's Avatar
Thumbs up
Danielsan; Glad to hear all is well. Since the Bay Mazda guys did a good job I I'll leave my plate holder on a few more weeks. :D Is that okay Mic?? :D
05TR1CH
Apr 18, 2023 04:56 AM
SupraG
Sep 21, 2015 12:09 AM
foxyRoXy8
Aug 18, 2015 10:26 PM
vetteor8
Jul 25, 2015 11:43 AM
RX7.9
Jul 20, 2015 12:01 PM
