NEED HELP. 18x9.5 off 35 will this fit?
Old Apr 12, 2005 | 03:29 PM
whosyourbaba's Avatar
Hey
I searched for 18x9.5, couldnt find if offset 35 would fit the front or back. im more worried about the front as people are getting 8.5 for the front. Interested in some used te37, guy is selling them 18x9.5 with off 35. Would these work?
Also, which tire size would work for 9.5.
Tire rack says 245/40/18
Read someone using 265/35/18
thanks for the help.
Old Apr 12, 2005 | 04:59 PM
poorkorean's Avatar
is it the same bolt pattern?
if its the same bolt pattern it will fit... but your wheels will be sticking out if the offset is 35...
will cause an uncomfortable ride cuz its gonna be rubbin when you go over a bump
Old Apr 13, 2005 | 12:13 AM
yea, its the same bolt. o, thanks for the info.
Old Apr 13, 2005 | 12:50 AM
Fanman's Avatar
I have 19" x 8.5" front w/ 38 mm offset & 19" x 9.5" rears with 35 mm offset. The 38 mm offset rubbed my caliper just a very little bit. You should be fine with 35 mm offsets across the board. The 9.5" fronts would stick out quite a bit, as my 8.5" pushed out 31.5 mm (38 - 6.5 mm) is pretty much right at the outside of the bumper. a 9.5" would stick out about .8 inches.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Evan Gray
Nov 24, 2015 01:00 AM
RAVSPEC
Vendor Classifieds
Oct 1, 2015 01:59 PM
GranTouTou
Sep 30, 2015 06:11 AM
GK1707
Sep 27, 2015 07:33 PM
