View Full Version : A Saturday with Mazdaspeed
DynamicDookie
04-11-2005, 06:16 PM
everything went smoothly....except for the foglight install. not sure why mazda didn't include harware with the brackets or even acknowledge them in the instructions, but after much cursing and gnashing of teeth.....
http://www.tdico.info/81a.jpg
http://www.tdico.info/82a.jpg
http://www.tdico.info/83a.jpg
...you can see my buddy's evo in the background. next weekend skirts. the rear the weekend after that.
the run lights and corners are super white leds from superbrightleds.com. The leds were cheap enough that I bought serveral types of white leds. some of them had a slight, subtle blue tint. the camera might have enhanced the blue. the fogs are piaa xtreme white.
truemagellen
04-11-2005, 06:26 PM
looks HOT! My sunlight silver says hi :D
Mindtrip
04-11-2005, 06:39 PM
Look really good with all the blue HID's
RA-Eight
04-11-2005, 07:19 PM
Looks really good! Can't wait to see the whole setup! Where did you pick up the kit? How much?
mikeb
04-11-2005, 07:59 PM
what kinda bulbs are those
looks too perfect
St.Char
04-15-2005, 12:13 AM
Those fog lights brackets aren't easy to install, however the directions for them are hard to follow. I thought that this was the most time consuming part of all, just wait till you get to the skirts. - Looks great, good luck!
Smoke Honda
04-15-2005, 05:48 AM
Which ones did you order? Do I need HID lights to use this?? -thanks
Columbus
04-15-2005, 09:29 AM
I love the mazdaspeed kit. Too bad I don't have 4 grand lying around.
DynamicDookie
04-15-2005, 01:12 PM
The fog brackets were really tough (time consuming is right...notice the passing of time in the photos). I'll do the skirts today or tomorrow.
I should have done the skirts first and then the front and rear. Tein S, plus the lower front are make it hard to get the car up on jack stands.
DynamicDookie
04-15-2005, 01:21 PM
the fog brackets are mazdaspeed. i got them from trussville for ~$65.
i don't think you need the xenon headlights, but the brackets are cut to take the glass housing from the oem fog lights....not sure if you can just buy the glass housings. you might need to buy the mazda fog light kit if you don't have fog lights.
btw. for anyone trying to install the mazdaspeed fog light brackets without instructions....line up the angle on the fog light hole with the inside edge of the bumper.
Kel Rx8
04-15-2005, 02:53 PM
looks nice and mean
congrats
Smoke Honda
04-15-2005, 04:47 PM
sorry, i meant what lights did you order from that website. The running lights, and the headlights. Basically the HID, which ones did you order from superleds.com and do I need xenons to use them to replace my headlights bulbs. Or are those xenons in the picture? -thanks
DynamicDookie
04-15-2005, 10:04 PM
the headlights are the stock xenons, the run lights and corners are super white leds that have a slight blue tint
oyester
04-15-2005, 11:21 PM
hi..just wondering did u order the kit painted/unpainted? cos japan colours might be different from other country...
truemagellen
04-16-2005, 01:04 AM
they aren't different...although the way the paint is layed on may be different...so may look a little 'off' in a different lighting...a great paint job near your home may turn out better as they can spread the paint in the same direction to make a very similar look...but unlikely they will do a great job anyhow
DynamicDookie
04-16-2005, 02:16 AM
painted, i'm sort of a perfectionist and the silver matches perfectly. i don't think the colors are different between countries.
i was concerned about paint fade/change and bought the kit as soon as i could. darker colors may be more prone to fading/changing over time (e.g. maybe if you bought a black or red in 2003 and parked it outside, there may be a slight color variation if you were to mount the painted kit now.....
