Have HID housings/bulbs, how to retrofit?
Old Apr 11, 2005 | 12:35 AM
Silverarrow's Avatar
OldeSpeede, Inc.
Ok, i purchased the HID housings for the rx8 with bulbs, ballast, motors etc. i want to replace them. Does anyone know if this is a direct bolt in? Will the extra wiring be there in the loom someplace? Anyone have any experience with this exact situation? These are the factory housings etc. not aftermarket.
Old Apr 11, 2005 | 01:18 AM
Rotary Rasp's Avatar
503wtq Boosted Bimmer
You're not going to be able to hook up the auto leveling motors, they require senors on the front and read of the car. Other than that, they should drop right in.
Old Apr 11, 2005 | 01:21 AM
StealthTL's Avatar
Metatron
Hid....
For sure you can get them going, just won't be able to use the levelling motors, you don't have sensors on the 'axles'.
You will need to use a 15 amp fuse to EACH - the halogens, I think use one 15 for both.
Keep us posted on your progress, we are here to help!
S
OldeSpeede, Inc.
interesting, have any part #s?
I wonder if there is a "sub" harness that would include all of those attachments....i was under the impression that all the pigtails would be there, just tucked into the loom...a la gm.
Old Apr 11, 2005 | 01:43 AM
If the car didn't come with it from the factory, the wiring won't be there. You can count on that.
arexatemate
Oct 9, 2015 06:23 PM
wayloco
Sep 1, 2015 09:03 PM
beastman_5
Aug 30, 2015 10:22 AM
