4-PT Front & Rear Strut Braces
Old Apr 5, 2005 | 07:54 PM
Spin9k's Avatar
Momentum Keeps Me Going
Autoexe 4-pt Front & Rear Strut Braces
Just installed these Autoexe braces. Thought you guys might enjoy a few pics.
The front bar truly braces the engine compartment. The corner arms use 1/8" steel plates to sandwich the side inner fender to the strut bar. You have to get into the fender area in the wheel well to rachet the bolts down, but not too hard. The circular strut tower extensions bolt right to all three struts bolts. The stock bar only uses two bolts and then some weird bracket piece underneath. The stock bar is extremely light weight feeling. These make things rock solid, I esp. like all the triangles created for strength.
Attached Thumbnails 4-PT Front & Rear Strut Braces-front.jpg   4-PT Front & Rear Strut Braces-crosslook.jpg   4-PT Front & Rear Strut Braces-side2.jpg   4-PT Front & Rear Strut Braces-brackets.jpg   4-PT Front & Rear Strut Braces-side.jpg
Old Apr 5, 2005 | 07:58 PM
Spin9k's Avatar
The rear bar massively improves whatever lack of stiffness and strength there is in the back area. Note the stock two bolt bracket that holds the strut itself. Thats it. The Autoexe tower brace bracket is a sold 'U' steel plate top to bottom with two additional bolts at the top (using the other two pices of hardware in the pic above). The welded cross tie piece can then do its work effectively, keeping the towers from moving out of line. Whatever movement was possible before back there, is gone now. :D
One cool thing is by just taking out 4 bolts, the cross piece comes out, leaving only the little red pieces sticking through the liner. Practically invisible then, and more room...but what's left behind the liner is a heck better brace than stock, even wo/the cross piece!
How do they feel? Well I've done these things as well, a battery change/move, and Whiteline adj sways front and rear set full stiff ... so it is (will be) difficult to tell what comes from what, but the combination makes the car as different again as say going from a normal car to the 8 IMHO. The car positively changes direction without effort, much lighter feeling on its feet, and no noticeable lean whatsoever. I'm hoping for some major improvements to the tail's behavior.
The sways came with nice new (yellow) stiff bushings, no give at all... whereas the stock bushings feel like a toilet plunger... very pliable and weak. I may notice a slight increase in tire noise, but no new suspension sounds from anything yet.
Will go to NHIS for an HPDE 4/27 and put it to all the ultimate test, hopefully it will do all I am expecting :D I'll come back and post results then.
Attached Thumbnails 4-PT Front & Rear Strut Braces-old-rear.jpg   4-PT Front & Rear Strut Braces-rear-new.jpg   4-PT Front & Rear Strut Braces-rear-2.jpg   4-PT Front & Rear Strut Braces-rear.jpg
Old Apr 5, 2005 | 08:16 PM
Thetitanium8's Avatar
Mr. Skinny
very nice.. those are the ones I want to get.
Old Apr 5, 2005 | 08:22 PM
goforwand's Avatar
Raced with Joy & Abandon
I've been kicking around the idea of the Autoexe set up for a while. I'm really interested in hearing your impressions!
Did you have to wait for it or did someone have it in stock?
Did you consider the 4 piece member brace set for under the car as well?
Nice pics of the rear brace (I was wondering how that was installed )
Old Apr 5, 2005 | 08:37 PM
Spin9k's Avatar
They're beautiful! High high gloss red finish, nice 'Autoexe' name plates on each, they simply dress up where they're at. :D
I ordered them at Mazdaparts. I thought they stocked them, but it turned out they had to write to somewhere in Japan juts to get a quote after I ordered, well anyway I had them sent by boat and it was about a month to get them, but it was also fairly inexpensive (<$100).
I didn't consider the underbrace, maybe next year
Thanks, I'd never seen a series of pics showing how it was done as well, glad you like it. I was really surprised how little support, stock, there seems to be for that rear strut housing.
Old Apr 5, 2005 | 10:06 PM
Speed Racer's Avatar
Certified track junky!!!
Looking good!
I can't wait to check this out in person. :D
Old Apr 6, 2005 | 09:49 AM
RotorManiac's Avatar
Absolute Rotary Madness
very nice
this company makes very functional aftermarket parts... I'm not very fond of their looks :o
the rear one is a peace of art!
Old Apr 27, 2006 | 09:24 PM
scsi's Avatar
so the autoexe front brace doesnt have a master cylinder brace as the MS one does?
is any drilling required for any of the bars or do they both bolt into existing holes? did you have to cut the fender liner yourself?
also, how would this affect adjusting tein flex by hand (i dont want an EDFC unless i have to)
Old May 4, 2006 | 06:17 PM
Spin9k's Avatar
- No it doesn't have master cyl brace. They sell an elaborate one separately, but it is only for RHD models.
- no drilling, all existing holes
- no just undo a couple lower plastic push nuts behind the front wheels, pull the liner out of the way a bit and stick you hand in w/a wrench, then use a socket wrench to tighten the other side from under the hood. I did it alone w/no help.
- see the 3rd pic in the 1st post (front). That kinda shows that what attaches to the tower is basically a hollow tube. So anything on your strut is just as available as before no problem.
- in the back...ummm, different situation. Looking at the pics the brace pretty much covers up the reach thru area to do anything to the top of the strut tower. You can see that in the pics...but I'm not quite sure how a tein flex fits in there either? If there's a cable thingy, that might work.
Hope that helps.
Old May 4, 2006 | 06:21 PM
sorry if i missed it but how much did the front and rear struts run you? thanks..
Old May 4, 2006 | 06:23 PM
Spin9k's Avatar
I got them here http://www.mazdaparts.com/ProductDet...001-1118217491 for the same price and see earlier post about ordering from them.
spin
Old May 4, 2006 | 06:38 PM
thanks...very nice by the way!
Old May 4, 2006 | 08:06 PM
scsi's Avatar
haha thanks spin :P
Old Jun 17, 2006 | 05:05 PM
DOMINION's Avatar
I don't buy Kool-Aid
WOW thats hot think I can get them then paint then blue?
Old Jun 17, 2006 | 07:08 PM
NgoRX8's Avatar
you can powdercoat them
Old Jun 17, 2006 | 11:21 PM
army_rx8's Avatar
X-Sapper
i'm thinking of getting them adn powdercoating them silver now tha ti se these pics....wish it had a master cylinder brace though ah well can't win them all i guess.
Old Jun 18, 2006 | 02:26 AM
NgoRX8's Avatar
buy me a set please.
BigMikeATL
May 26, 2016 12:31 AM
rxwilly8
Sep 2, 2015 02:42 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
