Help, need a picture of the clockspring
Old Apr 1, 2005 | 12:55 PM
ddogg777's Avatar
Is there anyone that can take or has a picture of the clock spring behind the steering wheel? I am modding my P5 to accept the RX8 steering wheel and would like to see if the clockspring's bolt pattern is the same as the P5. It should have three bolts, I just need to know where they are.
BTW, does anyone know the cheapest online place to get parts such as this?
Thank you in advance!
Old Apr 1, 2005 | 01:07 PM
expo1's Avatar
He's as bad as Can
Don't know if this helps.
Old Apr 1, 2005 | 01:45 PM
ddogg777's Avatar
Thanks Epox, that looks very promising indeed! :D
It looks to have the same bolt pattern so I think I will give it a shot and order one. I have already verfied that the steering wheel fits to the column, now I just need to order the clockspring and perhaps the connector/harness behind the clockspring to splice into. You wouldn't happen to have a parts catalog would you?
On a side not, it looks as if I won't be able to connect the airbag since the RX8 bag has two igniters (each ~2 ohms) whereas the P5 bag has only one igniter (~3 ohms). Oh well, I don't really like airbags anyway...
Evan Gray
Nov 24, 2015 01:00 AM
Digitz0070
Oct 7, 2015 12:43 PM
Hunterkelley24
Oct 1, 2015 09:11 AM
archon
Oct 1, 2015 06:08 AM
drlubell
Sep 26, 2015 11:58 PM
