My car wont start ><
Old Mar 31, 2005 | 05:10 PM
Dotson408's Avatar
I have like 11kmiles on my 8 and it turns on and has good lights and power but it wont turn over it just whines but wont fire...lol...
Any clue what could be wrong...??
Thanks.
Old Mar 31, 2005 | 05:13 PM
GotZoom's Avatar
Enjoy Every Sandwich - WZ
Gas
Old Mar 31, 2005 | 05:14 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
Flooded!
Old Mar 31, 2005 | 05:16 PM
Dotson408's Avatar
No when you turn the car on it shows the gas before fully starting I have plenty of gas I never let it get down past a quarter of a tank lol
Old Mar 31, 2005 | 05:17 PM
Dotson408's Avatar
And when the key is turned on somewhere in the engine bay I can here like a noise like a noise that sounds...like beeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeeee like faint like.
GotZoom's Avatar
Dotson...how does it sound again? I think I might know.
Is it like a Beeeeeeeeeeeeeeeeeeee
or a little lower like a baaaaaaaaaaaaaaaaaaaa with breaks in the middle?
Old Mar 31, 2005 | 05:18 PM
Dotson408's Avatar
How can it be flooded...and how do I start it?? lol
Old Mar 31, 2005 | 05:19 PM
Dotson408's Avatar
Its like a humming noise lol...
Old Mar 31, 2005 | 05:20 PM
GotZoom's Avatar
Like the rotary sound when it is running or like a baaaaaaaaaaaa low pitched hum?
Old Mar 31, 2005 | 05:27 PM
Dotson408's Avatar
Low pitched hum...
Old Mar 31, 2005 | 05:30 PM
GotZoom's Avatar
Low pitched hum...
Ohhhhhhhh..........
That is different.
Old Mar 31, 2005 | 05:32 PM
Dotson408's Avatar
I think it is supposed to do that tho...
Old Mar 31, 2005 | 05:33 PM
GotZoom's Avatar
But it just doesn't start right?
Old Mar 31, 2005 | 05:38 PM
Dotson408's Avatar
Could it be my plugs?
Old Mar 31, 2005 | 05:39 PM
Dotson408's Avatar
It will whine like its cranking but will not hit and fire
GotZoom's Avatar
Does it try to turn over if you don't push the gas pedal?
Old Mar 31, 2005 | 05:46 PM
Dotson408's Avatar
no
Old Mar 31, 2005 | 05:49 PM
GotZoom's Avatar
OK....it's not a Beeeeeee. It's more of a Baaaaaaaaaa low hum.
You have gas.
And it doesn't even try to turn over with pushing the gas pedal.
Is that correct?
Old Mar 31, 2005 | 05:53 PM
Dotson408's Avatar
Yes...
Old Mar 31, 2005 | 05:59 PM
Flooded :P
Old Mar 31, 2005 | 06:00 PM
Dotson408's Avatar
How do I get it unflooded?? lol..I drove it yesterday evening and now it wont start lol...
Old Mar 31, 2005 | 06:08 PM
Go48's Avatar
Yes...
Call Mazda Roadside Assistance and have them pickup the car and fix it under warranty. Or at least read the section of the owners manual that deals with de-flooding an engine. Fully charge the battery, do the de-flooding procedure and if that doesn't get it started, you nee to turn the problem over to Mazda.
Old Mar 31, 2005 | 06:23 PM
howardteets's Avatar
The low hum you hear is probably the fuel pump. When the key is first turned to the accessory position the fuel pump relay is triggered for a few seconds to prime the fuel line.
I just took my 8 out of storage and was checking the air filter and disconnected the MAF sensor to open the airbox. I forgot to re-connect it. I didn't think anything of the CEL and battery light on due to the fact that I just re-connected the battery for the first time in 5 months. Started fine the first time but after it would only start by manually giving it gas from the pedal. I doubt that this is your problem but it's something possibly worth checking.
Old Mar 31, 2005 | 06:26 PM
Dotson408's Avatar
Well, I tried cranking it got it to fire but it died now My battery is dead from trying to get it to start ...lol...My im charging it haha
Old Mar 31, 2005 | 07:07 PM
It's flooded, the more you try to start it, the more the battery will die out.. most likely you'll have to get it towed and have it fixed. Or you can try Deflooding it yourself with the DIY thread... but since your car is still under warranty, might as well let them handle it.
