Smoke from engine
Old Mar 27, 2005 | 07:36 AM
r55790's Avatar
Need More Speed
Smoke from engine
Hey guys:
I have a 2004 RX-8... 22k miles. Took the car for a spin and when I got back to my place, I turned the car off, and then all of a sudden smoke started coming out from the passenger side of the hood. I smelled burned oil and opened the hood but couldn't find any oil anywhere.
Some background info -- I just experienced my first (and hopefully last) flooded engine four days ago. Couldn't get the engine to start using the deflood procedure so I had to have it towed to Mazda -- great thing is that they fixed it for free even though they said it was not under warranty since it was due to driver error -- whoops.
I am going to take the RX-8 into the dealership Tuesday but if you guys have any suggestions, that would be great. I've learned a lot of great things and fixes on this car and would like to have some suggestions to help them fic this problem ASAP.
Thanks for any help,
-sjm
Old Mar 27, 2005 | 08:48 AM
Go48's Avatar
Originally Posted by r55790
Hey guys:
-sjm
Guess: One procedure for starting a no-start car is to add a few cc's of oil through the vacuum ports for each rotor/chamber. (See page 7-8 of the "Engine Cranks No Start" service bulletin at the link below for more information and pictures.) The ports are on the passenger side of the engine and look like 2 little tubes, dare I say nipples, sticking out of the intake manifold. If the tech used that approach to getting your car started, he may have spilled a little oil on the engine and what you see is that dribble burning off. I suspect that if care is not taken when detaching the hoses from the vacuum ports, it would be very easy to spill a little oil. Or worse yet, he may not have replaced the plugs on the ports after doing that procedure.
Take a flash light and see if you can see any spilled oil and while you're at it verify that the port plugs are in place.
http://www.finishlineperformance.com...ins_index.html
vapor2
Nov 3, 2020 03:38 PM
uZu
Dec 30, 2015 12:35 PM
marc2820
Jul 26, 2015 10:47 PM
Bamaham
Jul 23, 2015 08:08 AM
RotaryRider
Jul 20, 2015 07:05 AM
