smells like burning matches
Old Mar 26, 2005 | 02:58 PM
beifstu's Avatar
drive it like u stole it
I've read the posts about the rotten egg smell that happens during start up but will go away after about a week. But...I've owned my car for over a month now and just started getting a bad smell when I warm up the engine before driving. Smells like burning matches.
Old Mar 26, 2005 | 03:07 PM
alnielsen's Avatar
Burning Matches / Rotten Eggs probably the same sulfer smell comming from the cat converter.
Old Mar 26, 2005 | 03:30 PM
Mikelikes2drive's Avatar
i still had it after 2 or 3 months afterwards. dont wry
Old Mar 26, 2005 | 05:53 PM
guitrblus's Avatar
Not my X-ray
i had a problem with a plastic bag that melted to the heat shield underneath. it got caught under the car while driving. the smell lasted for a good couple of weeks. chack under and make sure that nothign is tucked in there. just a suggestion. sometimes its the simplest and stupidest answer.
Old Mar 26, 2005 | 08:20 PM
Ellar's Avatar
The sulphur smell happens when raw fuel dribbles into the cat and then ignites. If that happens enough, it can kill the cat. The ceramic foam block in the catalytic converter eventually turns into dense chunks.
Rotaries do run seriously rich at startup normally, but with the smell, you may want to bring it in and have the shop take a look at why it's running rich even for a rotary.
Old Mar 26, 2005 | 08:26 PM
Ellar's Avatar
You could also be using a brand of gasoline that has more sulphur than most. Maybe experiment with that first?
Old Mar 27, 2005 | 10:34 AM
BasenjiGuy's Avatar
Are you sure you're not just smelling the normal oil and gas exhaust smell?
The RX-8 exhaust smells differently than a piston engine due to the minute amount of oil that rotaries inject into the combustion chambers to lubricate the seals.
Old Mar 28, 2005 | 01:26 PM
r8ped8's Avatar
ahhh,
the smell of Castrol in the mornin' :D
Old Apr 22, 2005 | 05:12 PM
Matt RX8's Avatar
I find that the oil burning smell is similar to the small of urine after you've just eaten aspargus...
Old Apr 22, 2005 | 05:33 PM
Glyphon's Avatar
脾臓が痛みました
i don't really see that at all, and i think i just learned a little too much about you :p
Old Apr 22, 2005 | 10:48 PM
Yes, it's either the CAT or bad fuel. Don't buy cheap gas.
Take it to the dealer, let them chewck it out.
Old Apr 22, 2005 | 10:56 PM
Rotary Titus's Avatar
I've had that smell on my car for more than 6 months, and only recently has it gone completely away so yea don't worry too much about it.
WranglerFan
Aug 21, 2022 01:29 PM
Ovr-9000
Apr 7, 2016 11:19 PM
XianUnix
Sep 29, 2015 03:48 PM
Jb4ker96
Sep 27, 2015 10:06 PM
