Oil question
Old Mar 23, 2005 | 08:23 PM
bNguyen's Avatar
Oil question
Hey all, I took my 2nd Gen RX7 in for service because I wanted to make sure what needed to be changed and so forth. While in service they changed my oil...the factory shop says 20W50 but the oil that was placed was 5W20. I was informed the 5W20 was used in the RX8 but can you please tell me if anyone out there who has an old RX7 can tell me if this "new" oil for the RX8 is usable in a 2nd Gen RX7. Thank you
Old Mar 23, 2005 | 08:38 PM
KKMmaniac's Avatar
VW coulda had it...
I wouldn't unless driving in ~0 deg. F temperatures. The Renesis was designed (or so we assume) to use 5W-20 oil, and the oil is well cooled by the twin (our 6-sp. anyway) oil coolers.
I use 20W-50 in my 1st gen. RX7 which I drive during the summer only, but then it has only the beehive (coolant cooled) oil cooler, which isn't nearly as effective for cooling as your air-to-oil cooler. I don't think the 5W-20 would have the film strength required for good protection at warm temperatures in the 7.
Old Mar 23, 2005 | 10:54 PM
Zootx8's Avatar
I used 20W-50 in both my '86 and '87 7's - I'd also stick with that, I'd be a bit miffed at the guy who did the oil change.
Old Mar 24, 2005 | 10:26 PM
mzdoggmann's Avatar
In this case, is the 5W20 oil still standard for the RX-8 even in warm climates like Florida or southern Cal in the baking summers?? Or should swap to a thicker oil during the hot seasons. Anyone w/ expertise pls advise.
Old Mar 24, 2005 | 11:25 PM
Zootx8's Avatar
there should be a temp range for the oils in the manual, it's in the car right now otherwise i'd look it up. i believe the 5W20 recommended covers a pretty broad temp range, but if you thought you'd be out of that range switching to a 10w30 may not be a bad idea.
Old Mar 25, 2005 | 03:45 PM
Nubo's Avatar
Lubricious
It's notable that Mazda specifies 5w30 in countries outside of North America. There wouldn't appear to be a mechanical reason for avoiding it.
mr. GrandGame
Sep 9, 2025 10:41 PM
05TR1CH
Apr 18, 2023 04:56 AM
Skyl3r
Dec 2, 2019 04:51 PM
MolecularConcept
Aug 5, 2015 04:43 PM
Obivious
Jul 29, 2015 05:57 PM
