View Full Version : Brakes
Razz1
03-23-2005, 08:20 PM
Ok, I installed new front rotors and all new pads front and rear.
Added new fluid and bled more than 1 quart through the system.
Brakes are very spongy. I have to push 3 to 4 inches instead of tapping them.
Is it possible to back out the piston too far when putting in new pads?
What is causing this spongy Feeling.
I swear there isn't any air in the system.
Do I need to get them pressure bled
Spin9k
03-23-2005, 09:07 PM
Did you bleed the underhood brake fluid tank both before and after you bleed the four wheels?
Razz1
03-23-2005, 09:10 PM
What?
You talking about the master cylinder?
expo1
03-23-2005, 09:20 PM
He is referring to this step mentioned in the shop manual.
TrackAddict
03-24-2005, 08:32 AM
I don't understand air-bleeding. I used a power-bleeder when I flushed my brake fluid and just followed the instructions on it.
Spin9k
03-28-2005, 07:23 AM
Don't know about power bleeding specifically, but likely you could do it to the master cylinder as well. Follow directions above (for the car) rather than on the PB pkg.
