new owners got some ?'s
Old Mar 22, 2005 | 09:26 PM
beifstu's Avatar
drive it like u stole it
My fog lights will not operate unless my headlights are on. Never had that issue with previous cars. Is this the way the 8's are suppose to be set up? Is the oil plug reusable or do you have to replace them with every oil change? when I get down to about a third of a tank I hear clunking sounds from the rear of the car. Is this the floater in my tank that measures my fuel volume? and if so is it normal for this sound cause it can be quite loud.
Old Mar 22, 2005 | 09:41 PM
Air Force RX8's Avatar
Who Cares?
Yes the fog lights will only work with the headlights on unless you re-wire them...search for the thread on how to do it...
Oil plus is reusable, but you should replace the "crush" washer each time.
I don't hear the sounds you are hearing, so I do not know if it is the float or not...sorry.
Old Mar 23, 2005 | 04:04 PM
Frank Patrick's Avatar
Not the float
The lights are wired that way- to prevent you from turning
High beam and the fog- too bright for oncomming traffic-
The float is affixed- unless something is amiss- you should not be hearing it bang around. the top vapor re-distribution shield, may be lose- which, after your fuel level goes down from fill a bit, might provide a little noise from the gas sloushing into it.
This can be fixed, under warranty by your dealer.
Old Mar 23, 2005 | 04:13 PM
Nubo's Avatar
Lubricious
FYI, the fog-light rewire thread is in the DIY section, which is in the Tech Garage section.
Old Mar 23, 2005 | 04:31 PM
Gord96BRG's Avatar
Yes, the fog lights only work when the low beam headlights are on - and that's because that is required by US Federal law, not Mazda. I doubt you had other cars with factory fog lights that operated differently, again since that requirement is set by the US Gov.
Regards,
Gordon
theblinkof
Oct 4, 2023 05:24 PM
mdl0209
May 23, 2019 05:46 PM
Quiggs321
Sep 30, 2015 05:34 PM
FubarI33t
Sep 28, 2015 08:45 PM
