To fix or not to fix...
Old Mar 22, 2005 | 04:13 PM
crosswound's Avatar
i thought you where supposed to get the break squeal since the brakes are so good and they are doing their job?
Old Mar 22, 2005 | 04:15 PM
JonsToy's Avatar
Registered Rep
I, too, was concerned that the original harder brake pads would cause premature wear on the rotors. Since the rotors are not covered by the TSB, I felt I'd be better off to replace the pads now than having to replace both the pads and rotors later. I find no noticable difference in braking with the new pads, and there is much less brake (or rotor) dust generated.
Old Mar 22, 2005 | 11:16 PM
sferrett's Avatar
Whaaaa?
Mine was squealing (23k miles) and I mentioned it last service and the TSB. They said they cleaned the pads and calipers and couldn't reproduce. It's now back to doing it (although less) and I'm really not that concerned about it. The car stops just fine so unless the noise becomes distracting (which it's not) then I'm not going to bother hassling with it. I guess I'm just a low-maintenance owner?
Old Mar 22, 2005 | 11:34 PM
Vertigo-1's Avatar
Mines started squealing at 3000 miles or so, and it only seems to be my rear right brake. Wouldn't really call it a squeal though...sounds more like a high pitched hiss. Sometimes it comes on at one brake stomp, and then if I release and reapply, it doesn't. I wouldn't be surprised if the dealership just considered it "normal". And incidentally the TSB at Rosenthal only deals with the front brakes.
Old Mar 22, 2005 | 11:39 PM
sferrett's Avatar
Whaaaa?
Yeah it's really not very loud... and very high pitched - although it only happens under light braking - if I increase pressure it'll stop (although usually just a litttle more pressure than I'd normally use to stop the car) - it's definately coming from the front.
Shankapotamus3
Mar 14, 2021 03:53 PM
Danield97
Sep 30, 2015 05:59 PM
DeltaJ802
Sep 29, 2015 01:20 PM
kody59
Sep 28, 2015 03:43 PM
drlubell
Sep 26, 2015 11:58 PM
