How much brake fluid?
Old Mar 20, 2005 | 09:05 PM
ScudRunner's Avatar
On time, on target
I did a few searches, and didn't find an answer to this question. Also checked the RX-8 manual and didn't see an actual number. I am planning to replace my brake rotors and pads, and will flush, not just bleed, the brake fluid at the same time (I am switching to ATE Super Blue). How much brake fluid am I going to need? I want to make sure I have enough, but at $10 a liter, I don't want to buy too much either. Thanks.
Old Mar 21, 2005 | 12:25 AM
Cam's Avatar
Cam
this space for rent
Ive always heard a good rule of thumb is to have 2L on hand.
BTW, I was thinking of switching to the ATE Super Blue. Please post your experiences.
Old Mar 21, 2005 | 09:54 AM
PUR NRG's Avatar
You'll use maybe 2/3rds of a liter. I like to switch between Super Blue and Typ 200. They're identical except for color which makes it easier to tell when new fluid has reached the caliper.
________
Kitchen Measures
Old Mar 21, 2005 | 10:43 AM
TrackAddict's Avatar
I miss my 'Bu
I switched to Super Blue 2 weeks ago. You will need only a one liter can. I didn't know what I was doing and wasted a bunch of brake fluid and still had some left in the can. About 2/3 of a can sounds about right to flush the whole system.
It looks like I put windshield washer fluid in my master cylinder
PUR NRG - how often do you bleed your brakes? How often do you replace all the fluid?
Old Mar 21, 2005 | 10:58 AM
PUR NRG's Avatar
General rule of thumb is you want to flush at least once a year. Since brake fluid absorbs water I like to do it right after the rainy season.
The only reason to bleed brakes is if there's air in the lines or it boiled during a track event. Once a can is opened the fluid starts to absorb moisture--even tightly closed you should throw the can away after three months. Because of that if I ever need to bleed the brakes, I'll do a complete flush. Better to have new fluid in the car than throw it away in the can three months later.
________
VENICE BEACH
Old Mar 21, 2005 | 01:11 PM
I miss my 'Bu
What is the indication you boiled your fluid? I don't think I did especially with the Super Blue stuff but it would be good to know for future reference.
Old Mar 21, 2005 | 01:53 PM
PUR NRG's Avatar
Boiling brake fluid usually occurs only on the track. You'll know because the brake pedal response feels spongy/mushy and the car isn't braking as quickly. Go easy on the brakes for the next lap and it should feel much better, but still not as good as before.
________
Lovely Wendie99
theblinkof
Oct 4, 2023 05:24 PM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
XianUnix
Sep 29, 2015 03:48 PM
