twin oil coolers
Old Mar 20, 2005 | 04:57 AM
rotarenvy's Avatar
Question twin oil coolers
in .au we don't get the twin oil coolers the jap and us cars get.
I'm looking at fitting another oil cooler and was wondering if the jap and US cars use the same size cooler in series or how is it plumbed in?
Old Mar 20, 2005 | 06:26 AM
Go48's Avatar
See the attached pages from the shop manual. The second oil cooler is essentially the same as the single cooler on the auto. The "oil cooler duct" is a mirror image of the comparable part on the other cooler. Unfortunately, I could not find anything in the manual on the plumbing connections. If no one else chimes in with that, I'll take a look at mine later today and post the info and possibly some pics.
Attached Thumbnails twin oil coolers-cooler_1.jpg   twin oil coolers-cooler_2.jpg
Old Mar 20, 2005 | 07:41 AM
Go48's Avatar
This ought to help.
Attached Thumbnails twin oil coolers-cooler_3.jpg   twin oil coolers-cooler_4.jpg
Old Mar 20, 2005 | 02:58 PM
rotarenvy's Avatar
thanks that was excelent!
:D
Old Mar 20, 2005 | 03:04 PM
Go48's Avatar
:D
Glad to help a fellow owner!
Old Mar 20, 2005 | 03:53 PM
Lock & Load's Avatar
Jarl
As soon as i supercharge my ride i will be looking at an aftermarket cheaper larger capacity and more efficient oilcooling system for my RX8.
cheers
michael
Old Mar 20, 2005 | 05:13 PM
takahashi's Avatar
Taka reviews after adding 2nd oil cooler
**Taka reviews after adding 2nd oil cooler**
I have the oil cooler fitted recently Jarl, with a MazdaSpeed (RHS) oil cooler
Try to get the MazdaSpeed or the US, Hong Kong or Japan spare parts. I suspect they are different but what the hell it is still an oil cooler. Japan does not have oil cooler in the Type S as standard but most people will have that as option. Certainly they mostly opted for the MazdaSpeed version of the oil cooler (btw it looks the same as the other one I have now )
There are many oil cooler available as an aftermarkey option, such as HKS and Fujita engineering, just to name two.
They are very pricey and go over the $1000 mark. So I choose the $600 MazdaSpeed one instead.
What you need is a garage, really. I will recommend changing oil and oil filter at the same time. It does mean a cleaner job. Make sure you take care of the joints and prepare for an oil leak (did have some on my installation). The right oil cooler gets the first of the oil from the central (engine) side and they travel to the left (stock) one before going back to central. There is a bass tube (as shown in the attachement above) to connect the right to the left oil cooler.
Get a quote for $300 installation since it will take someone 6 hours to do (inc changing oil). Make sure they run the car for 10 minutes before putting the front bumper back up, just to see if there are still leaks.
Result is amazing, central console is not hot anymore, well... it is cooler than what it has been. Say the temp in the cup holder used to be like the upper tray of the coffee machine (the area that warms the cup). Now it is like the keyboard of your laptop, still warm but certainly the house key I put in the cup holder will not burn my finger anymore.
MazdaSpeed oil cooler is race proven. In BestMotoring, people raced for 20 minutes in the heat, MazdaSpeed oil cooler has a oil temp of 100 degree cel, but the S2K and Integra are running at 130 degree plus. The water temp will still go up above 110 though, so I think it need to be changed at some stage, especially FI is required.
Jarl, I have the installation manual in Japanese. If you want it, I can fax it to you.
Taka
Old Mar 21, 2005 | 08:59 PM
zaku's Avatar
車の性能の違いが戦力の決定的差ではない ということを
Can I add this oilcooler into a AT car?
Old Mar 21, 2005 | 10:05 PM
takahashi's Avatar
The MazdaSpeed oil cooler I have is for MT ones only... I am not sure since there "may be" some difference connection of the AT cars in terms of oil cooling. I guess they might have the AT transmission cooling too?? No idea
RXFEVER
Aug 29, 2018 10:14 AM
RXFEVER
Sep 11, 2016 02:51 PM
9krpmrx8
Oct 13, 2015 01:36 PM
Sakebomb Garage
Vendor Classifieds
Sep 6, 2015 03:30 PM
