How do you start the car?
Old Mar 14, 2005 | 08:58 PM
HardHitter's Avatar
Well, it's strange, sometimes when I start the car it starts right up with no problem, and then sometimes when I start the car it seems as though it's struggling to start and it barely starts. What's with this? Someone told me it's because the 8 has a weak stock battery because if I have my phone plugged into the car charger and then try to start it, it seems as though it's draining it a little and it takes a while to start it, same as if I hold on brake down, as if it's draining electricity from the battery during start.
I don't know, it's strange, but how do you start the car and does anyone else have this problem? I've gotten M flash.
Old Mar 14, 2005 | 08:59 PM
dazygirl415's Avatar
I've asked the dealership and read about this and it's completely normal. It can take up to 10 seconds before the engine cranks over. It's just the way it's designed. Don't worry.
Old Mar 14, 2005 | 09:02 PM
Rhawb's Avatar
Has the whole shit.
Yeah, it's normal. Seems to pull the hard start stuff a lot more frequently when it's cooler outside (below 50 at least). I've found that if it takes a bit to start, it'll crank real easy if you just stop and try again real fast.
Anyway, to answer your question, I usually start mine with the key. :D
Old Mar 14, 2005 | 09:06 PM
I was going to say that, but I didn't want to come off as a smart ***... :D
Old Mar 14, 2005 | 09:09 PM
Rhawb's Avatar
Has the whole shit.
Hahaha, no shame here! :p
Old Mar 14, 2005 | 10:04 PM
Vertigo-1's Avatar
I usually leave my key in the On position for about 30 seconds to let the fuel pump work. I get a smooth start about 98% of the time this way. Occasionally though I will still get the tuttering and scraping sounds before it turns over. I've actually had it start smoothest when its cold outside, and I'm more likely to get hard starts when the weather's warm or hot.
For a 100% guaranteed smooth start though, do the 3k rev before shutdown. Car starts up just about instantly every time I've done that.
Old Mar 14, 2005 | 10:26 PM
JM1FE's Avatar
weak battery
http://www.finishlineperformance.com...42-04-1429.pdf
Old Mar 15, 2005 | 08:31 AM
MrMethane's Avatar
I tend to notice that it has more trouble starting after the engine is already warmed up. For example, in the morning when the engine is completely cold it will usually start right up. But once its warmed up and I turn it off, lets say I go into a store for 10 minutes, when I try to start it sometimes it takes 5-6 seconds to turn over. Could be just coincidence since it doesn't happen everytime.
Old Mar 15, 2005 | 01:37 PM
PaulyG CT's Avatar
Originally Posted by abbid
Rev to 5k before shut down. I never crank for more than 3 seconds.
really dumb question: Do you kill the ignition while the car is reving at 3K-5K or let it return to idle before turning the car off
Old Mar 15, 2005 | 01:44 PM
Rhawb's Avatar
Has the whole shit.
I drop the throttle real abruptly before turning it off when I do that. It seems to make noises like it's coughing all the crap out of itself, so it makes me feel like I'm getting something accomplished.
Old Mar 15, 2005 | 01:50 PM
Gambit's Avatar
Screw gas mileage
I just give it one big blast up to like 6 or 7 then turn the key off
Old Mar 15, 2005 | 01:55 PM
bobf's Avatar
never hade a problem starting. I turn the key and it always has started within 2 seconds. I did buy a new battery.
Old Mar 15, 2005 | 02:16 PM
wintergrn's Avatar
refreshing
I also wait for the fuel pump and whatever else to finish clicking/whirring with the key in the ON position before turning to START. Seems to shorten the crank time.
The only weirdness I've seen is on a cold day with the engine mostly cooled down, but not completely cold yet. That seems to be more an issue with the idle control hunting all over the place, rather than a hard start though.
Old Mar 15, 2005 | 06:03 PM
MrJynx's Avatar
put the car on, beep 5 times then crank. For turning it off I have never reved it up, just doesn't seem right and i've never had one problem starting. even on -30c days
MrJynx
Old Mar 15, 2005 | 06:08 PM
markd's Avatar
Lawyer in training :)
It does seem right, though. When you're in park, the fuel supply to the combustion chamber is cut off, so stepping on the gas burns up the excess fuel that is in there. At least, that's what the Mazda video said.
Old Mar 15, 2005 | 06:29 PM
No More Oldsmobiles's Avatar
Custom User Title:
Hmm? Maybe I misread that, but doesn't there have to be some fuel going to the combustion chamber even in park?
Old Mar 16, 2005 | 12:15 AM
markd's Avatar
You would think, but the way Mazda depicted it in the DVD I received from them, they make it seem otherwise. Anyone with better know-how can certainly jump in on this one and correct any information I am disseminating.
Old Mar 16, 2005 | 06:22 AM
rocketpop's Avatar
I have never had a start up issue, it starts right up every single time. I never turn the car on for x amount of time before trying to crank it and I never rev my engine before shutting it down.
Old Mar 16, 2005 | 06:29 AM
rx8cited's Avatar
Senior Member
Rev to 5k before shut down. .....
Do you do this if the even if the car is warmed up? I don't and have never flooded.
delicious_dallan
Jan 17, 2020 09:17 AM
dbarber
Jul 25, 2015 01:34 PM
T_Mags
Jul 24, 2015 11:29 AM
Bomba
Jul 22, 2015 06:46 AM
Kangarhew
Jul 18, 2015 08:27 PM
