Will this cover body damage ?
Old Mar 14, 2005 | 11:19 AM
cgrx's Avatar
DRIVEN
I tapped an island with the bottom of the 8 in a random spot. Can I install a side aero flare and not have it be affected by any new "angles" ???
Attached Thumbnails Will this cover body damage ?-119_1914.jpg   Will this cover body damage ?-119_1915.jpg   Will this cover body damage ?-119_1916.jpg   Will this cover body damage ?-119_1917.jpg
Old Mar 14, 2005 | 11:20 AM
cgrx's Avatar
DRIVEN
damn, the pics make it look MUCH worse
Old Mar 14, 2005 | 11:38 AM
brothervoodoo's Avatar
RainMan is Back
That should be relatively easy for a bodyshop to adjust, it may need some manipulation, before installing the aero. The aero would definatley hide what's underneath.
Old Mar 14, 2005 | 11:51 AM
cgrx's Avatar
DRIVEN
Thanks for the pic !
Do you know if any of the mounting points are near the dent ?
The wheel well shape IS NOT changed - even though it looks like it is
Old Mar 14, 2005 | 12:46 PM
RainMan is Back
I'll check it and get back to you
Old Mar 14, 2005 | 02:03 PM
RainMan is Back
One screw in the back check links for higher res photos of the bottom.
http://home.comcast.net/~store0001/forstef/IMG_1220.jpg
http://home.comcast.net/~store0001/forstef/IMG_1221.jpg
It seems some of the insertion points for the flare have been tweaked probably need to straighten them out, doesn't seem too bad though.
Old Mar 14, 2005 | 02:47 PM
cgrx's Avatar
DRIVEN
THANKS !! sweet pictures
I think it'll work out
Old Mar 17, 2005 | 12:33 PM
cgrx's Avatar
DRIVEN
Any other opinions ??
Old Mar 17, 2005 | 12:47 PM
mrtux's Avatar
rx8 user
im not sure if there is adhesive tape along the top edge of the flare. though maybe if you placed it on, you could get some gapping from a top eye view between the flare and car from the dent. it might cover from a side view...but from top not too sure.
Old Feb 8, 2006 | 10:58 PM
cgrx's Avatar
DRIVEN
anyone else have an opinion ?
Thanks !
Old Feb 9, 2006 | 05:27 PM
i did the same thing but with my side flares on...it scratched the bottom only so you can't see it, only when you look under it.
ÜberJumper
Canada Forum
21
Feb 20, 2025 11:57 AM
LB2739
Jul 9, 2019 02:25 AM
MolsonB
Sep 11, 2015 12:24 PM
nivong
Europe For Sale/Wanted
Sep 2, 2015 07:54 AM
