difference between 04 & 05 rx8
Old Mar 10, 2005 | 10:42 PM
eeps24's Avatar
are there any differences between the 2004,2005 rx8? ....also is the flooded engine problem still the same in 2005?
Old Mar 10, 2005 | 11:07 PM
NoTears316's Avatar
Shock and Awe
The key...
Old Mar 11, 2005 | 01:26 AM
RX-Nbg's Avatar
The container for the window washer fluid.
The old one was of black plastics (not transparent), the new one is of white (or colorless) material and transparent. You can check the fluid level without opening the container.
That applies for Europe. For the US I don't know.
Old Mar 11, 2005 | 01:39 AM
BlueFrenzy's Avatar
Rotary Powered Decepticon
brother ... do a search.
Basically nothing. Like NoTears said .. a new key fob. Oh and no more yellow but instead white (and green in Canada).
Old Mar 11, 2005 | 02:41 AM
Navybeardbb's Avatar
flooding isn't really a big problem like it's made out to be.
Old Mar 11, 2005 | 05:27 AM
eeps24's Avatar
the dashboard is all the same......usally there is some difference with the next year...like different dashboard/lights/etc.......... thanks guys......just wondering if there were differeneces
Old Mar 11, 2005 | 07:14 AM
JM1FE's Avatar
  • Deleted yellow, added metallic white
  • New (VW/Audi-style) switchblade key/remote
  • Newer 'flash' version in the engine computer (older ones can be updated)
  • Newer firmware in the NAV and audio system (older ones can be updated to some extent - see mazdaparts.com)
  • Washer fluid tank is translucent, not black (can someone confirm?)
  • Different MAF sensor wiring (can someone confirm?)
These are the visible changes. There are certainly a lot of undeclared fit-and-finish changes and improvements, as there always are over the production life of a model.
Old Mar 11, 2005 | 07:30 AM
irish8's Avatar
Get in ma belly!!
  • New (VW/Audi-style) switchblade key/remote - 05 KEY AVAILABLE FOR 04
  • Newer 'flash' version in the engine computer (older ones can be updated) - LATEST REFLASH AVAILABLE AT YOUR DEALER
  • Newer firmware in the NAV and audio system (older ones can be updated to some extent - see mazdaparts.com) - UPDATE FOR 04'S AVAILABLE
I have owned my 8 over a year now and have had ZERO flooding issues!!
Good luck!!
- Irish
Old Mar 11, 2005 | 08:26 AM
fredw1's Avatar
The washer-fluid tank is white, which allows one to see the level without removing the lid.
While the other differences have been mentioned, my experience with my '05, after 1400 miles and two months:
No flooding
No broken climate-control buttons
Hot seat warmers
Cup holders are not "heated"
Relatively good heat output by the heater(not as good as other cars I have owned, but beter than others have reported with the 8)
No rattles or squeaks (hope I haven't spoken too soon)
No CELs
No problems with the console cover, but I keep it open most of the time
It seems that Mazda fixed a lot of the known problems with the '04s in the '05.
Same poor mileage (15-20 mpg)
Same amount of fun driving it (I take the 40-mile route to a destination 5 miles away)
Fewer gawkers (after a year of '04s, people are used to them now)
Old Mar 11, 2005 | 08:29 AM
Kewlb's Avatar
Poker Mogul
What does the NAV and audio system firmware update do for you?
I also noticed that Rosenthal Mazda advertised the OEM Bose unit as a CD/MP3 player what is up with that? Does it play MP3's or did they just put that in the description. I saw that and it got me all excited so I wasted a CD burning a bunch of MP3's and the damn thing didn't play.
Old Mar 11, 2005 | 08:45 AM
GotZoom's Avatar
Enjoy Every Sandwich - WZ
Oh yeah...one more.
The 2004 has a 4 at the end where the 2005 has a 5.
Old Mar 11, 2005 | 08:42 PM
Yes, one more!
I found out the front brake rotors are different for the 05 and 06.
Ummmmmm... what did Mazda find out?
The new rotors don't fit on the older cars.
Old Mar 11, 2005 | 08:48 PM
JM1FE's Avatar
That's an option. The default systems (Bose or not) don't play MP3 CDs.
Old Mar 12, 2005 | 11:00 AM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
I do believe the oil dipstick has been improved . . . has dots on it at half-quart intervals. Still fairly hard to read, though.
Old Mar 12, 2005 | 11:37 AM
Rotario's Avatar
Long Member
My '05 has a black tank.
Bill
Old Mar 12, 2005 | 07:03 PM
little666devil's Avatar
HAHA! Exactly what I do...Gotta love it! :p
Old Mar 13, 2005 | 02:57 PM
RX8 RX8 RX8's Avatar
I just saw two RX8's (05) in Puerto Rico with a different OME wheels that have slots cut into the spokes.........everyone lese might already know this, but I just found out.
Old Mar 14, 2005 | 11:48 AM
drsinfla's Avatar
For beancounters only
For me, the difference between the '04 and '05 was 1) getting the EXACT model color and options I wanted, and 2) about $4000 in depreciation which the dealership wasn't going to compensate me for by buying an '04 over an '05. So, I bought the '05.
Are there still '04's out there???? by mid model year 2005? unbelievable.
Old Mar 15, 2005 | 04:31 PM
Frank Patrick's Avatar
1st One Stolen
On my 2nd 8--My 1st was an 04- my new one is an 05- Other then some minor changes, the only real difference I have noticed is the -NAV system- definetly more up-to-date, but I suppose you could update the 04 system also.
It also seems to have a bit more launch-off line power, but that might be computer related, and seems like some (not all-rattles are gone)
Old Mar 15, 2005 | 04:33 PM
Hard 8's Avatar
Senior "Member"
Sounds like the smaller wheels on the automatic models.
Old Mar 15, 2005 | 06:14 PM
Tyler Durden's Avatar
I'm on my second RX-8 also , so far I see that the led's in the center cluster are slightly different . No better or worse , just different !
UHATEIT
Mar 31, 2019 05:31 PM
Mr.BigSpoon
Aug 9, 2015 01:15 PM
xandersonx97
Aug 2, 2015 01:02 AM
marc2820
Jul 26, 2015 10:47 PM
dmengel
Jul 18, 2015 09:35 AM
