WarpFactor
03-08-2005, 11:00 PM
Has anybody noticed a hissing sound in their car?
It seems to come from the right - rear portion of the car. The noise is intermittent. I've noticed it in 2nd, 3rd, 4th gears, while accelerating, cruising, or decelerating.
At times it sounds like it's sucking in air. Other times, it sounds like it's expelling air. In a way, it sorta sounds like the air brakes on a transit bus but not as loud and not as fast.
A search of the forum found the Mazda bulletin below, but that noise is at idle. My noise is during driving.
Any ideas?
WHINE OR SQUEAL NOISE FROM ENGINE AT IDLE
Applicable Models
Model Starting S/N Ending S/N
2004 RX8 00000000 ZZZZZZZZ
Some customers may complain of a high-pitched whine or squeal noise fromthe engine at an idle. The noise can be eliminated by raising the engineRPM slightly above idle. This is most likely caused by the primary port jet air nozzles and / or the metering oil pump air ports. The jet air nozzles are located in the primary port of each rotor. The jet air flow is acheived by using air flow from an area prior to the throttle plate. The metering oil injection nozzles also use this airflow prior to the throttle plate to assist oil flow into the engine. This creates a metered vacuum leak into the engine and may cause a high pitched whine at idle. This noise is considered to be a normal characteristic of the RENESIS rotary engine. Use the procedure outlined in the repair instructions to confirm noise is from the jet air or metering oil pump nozzles. 1.Confirm noise. 2.Remove engine cover. 3.Locate both air supply hoses for jet air nozzles and metering oil pump nozzles. Hoses are attached to the air duct located between the MAF and throttle body. Disregard hose that attaches to the oil filler tube4.Confirm noise is caused by jet air or metering oil pump nozzles by temporarily pinching off air supply hoses using pliers. 5.No repairs should be attempted if noise is reduced or eliminated.
Any ideas?
Applicable Models
