curious.......
Old Mar 6, 2005 | 01:05 AM
xxdevilzeroxx's Avatar
Revin 9500k
curious.......
mid pipes cause the check eng. lights go off right?, b/c of the O2 sensor .......eventho its connected on the pipe the check light is still lit. what whould happen if the O2 sensor isnt inserted at all? running the car w/o an O2 sensor mess up the performance in any way? xept for the bad gas mixture....
Old Mar 6, 2005 | 01:19 AM
E-brake's Avatar
If your new mid-pipe doesn't have a cat you will get a CEL. If you don't plug it in you will get a CEL.
You could put a resistor inline with the sensor to fool the ECU into thinking it's still reading properly
Old Mar 6, 2005 | 01:41 AM
StealthTL's Avatar
Metatron
Spikes.....
The computer has an upsteam O2 sensor which sends 'spikes' of signal according to how much oxygen is in the exhaust gases.
It then looks for a signal with less voltage spikes from the downstream sensor, indicating that some of that oxygen has been used up, in an afterburn on the catalyst.
No spikes, too many spikes, no sensor ohms or too high sensor ohms, (no sensor detected) will trigger the Check light. Not an easy signal to spoof......
S
Old Mar 6, 2005 | 02:22 AM
Revin 9500k
so either way when you use a test or mid pipe you will get a cel? does anyone have any pic of some available midpipes for out cars or test pipes?
Old Mar 6, 2005 | 10:12 AM
NoTears316's Avatar
Shock and Awe
Here is a link to the midpipe I have... never received a CEL.
http://www.srmotorsports.com/RX8_Per...tem_Parts.html
Old Mar 7, 2005 | 02:22 AM
Revin 9500k
anyone made their own mid pipe?
Old Mar 7, 2005 | 02:26 AM
truemagellen's Avatar
Attracts tree branches
yes you can get a catless mid pipe or a high flow cat with a dummy O2 sensor...no big deal :D no more Cel
Old Mar 7, 2005 | 02:27 AM
Revin 9500k
i heard those things dont work!
Old Mar 7, 2005 | 02:33 AM
Canzoomer sells them, I bet good ones do work
Old Mar 7, 2005 | 02:34 AM
Revin 9500k
what m/p do you have?
Old Mar 7, 2005 | 02:39 AM
stock, but check this out: http://canzoomer.com/CZ-Performance.html
Old Mar 8, 2005 | 03:05 AM
Revin 9500k
how does a stock muffler sound like with a mid pipe??? are we gonna loose or gain power/torque
