PLERX8
03-03-2005, 08:32 AM
I got this from the 350z-tech forum and thought it may interest some of you. Written by a gentleman named David.
"Tonight I had a chance to meet up with someone I know who has an RX8. We went to my 'testing ground' and we did some side-by-side comparisons. The RX8 is totally stock and has over 26,000km on the clock. My car has a Hi-tech exhaust and K&N Filter. Both cars had only the driver in the car and I had 2/3s of the tank full while the RX8 had less than 1/4. We did a few runs to try and get a feel of what's going on, and also we had a 3rd person flagging the starts so there shouldn't have been an advantage either way. Anyway, to the comparison ...
Acceleration comparisons:
- Test #1: 15 - 120kph, both cars in 1st gear:
First we tried a relatively slow roll-on acceleration test, and this one was not playing to the RX8's strengths as at 15kph it just did not have the revs high enough. Still, I wanted to see what would happen and as soon as we punched it I strongly pulled away. By the top of the 1st gear I was good 2 - 3 car-lengths ahead, and by the end of 2nd it was more like 5. Before we shut down (at around 120kph), I was good 6 car-lengths ahead.
- Test #2: 40 - 130kph, both cars in 1st gear:
Next time we decided to run a rolling-start from a speed that would play to the RX8's strength (ie. it would keep the revs up). So we started from around 40kph and this time I got a good view of the RX8 as it got on power a fraction earlier and pulled 1/4 car-lengths on my straight away. Though, as soon as I jumped on the power as well I was making the ground up and by the end of 1st gear I was about 1/4 to 1/2 a car-length ahead. Then after the 1st-to-2nd gear-change I would pull away even stronger and by the top of 2nd gear I would have good 2 - 3 car-lengths on the RX8. In 3rd gear I kept polling away and I'd say I was ahead 4 car-lengths or so by 130kph when we shut it down.
- Test #3: 0 - 125kph, both cars in 1st gear:
Last test we did was a standing-start comparison, where I propped the clutch from about 2,500rpm and the RX8 from about 5,500rpm. I got a pretty decent launch but the RX8 got a good launch as well and while my wheels were still spinning we were very much side-by-side ... if anything the RX8 was a couple inches ahead. Then when my rear-tyres hooked up I started to pull away and had about 1/2 to 3/4 car-lengths on the RX8 by the top of 1st gear. In 2nd gear the 350Z really got into its stride and was pulling away strongly, and consistently. I'd say at a good 1/4 car-length per second. Same goes for 3rd gear and by the time we shut down (at around 125kph), I'd be good 4 car-lengths ahead.
RX8 Impressions:
So I would say that the RX8 can launch pretty well ... probably due to its favourable weight and weight-distribution. It actually surprised me how well the RX8 launched off the line. Though, once on the move the 350Z was always quicker and very noticeably so in 2nd gear. I was not really close and it seems that in 2nd and 3rd gear the 350Z has a significant advantage.
I also hopped in the RX8's passenger seat to see how it feels from inside. The standing-start launch did feel pretty good, but the car just did not have the same pull that I feel in my car once on the move.
Though, once again I was pretty amazed by how quiet the car is from inside and also how soft it rides.
DavidM"
RX8 Impressions:
DavidM"
