Making a sealed sub box into ported?
Old Mar 1, 2005 | 01:17 AM
Tamas's Avatar
Registered Lunatic
Turning a sealed sub box into ported?
This one is for the folks experienced in audio and sub box fabrication...
Currently I have a sub that replaces the trunk pass-through (built by an audio shop). It houses a 8" driver and has a relatively small enclosure (pic1 and pic2).
It sounds pretty good and gives decent, tight bass - however, I sorta feel I'd like it to sound more "warm". Not sure how to put this... but basically I'm thinking that by going with a ported instead of a sealed enclosure, I would eventually get bass that might not be as tight but would sound warmer and probably a bit better in the car.
So the questions are:
- am I crazy or is this more or less a correct assumption?
- how easy / complicated is to change such an enclosure to ported and how should this be done? Any good advice you guys could give?
I realize that the 8" woofer will not give me huge bass and I don't need that either - but my PC's simple speaker system (also with an 8" driver and a ported box) gives me that warmer and just a little bit boomier sound.
Thanks.
Old Mar 1, 2005 | 09:19 AM
staticlag's Avatar
The Professor
You can't turn a enclosed box into a ported box without modifying it a lot. It is easier to just construct a whole new box.
Besides that, stereo system companies actually put a lot of time into the design of their speakers, employing engineers and the like to get their products just right. No offence, but the people working at stereo places are probably high school dropouts.
A lot of output sound quality goes hand in hand with: The shape of the box, whether its filled or not, and the size in comparision to optimal dimension.
If I wanted a quick-fix solution to your problem, I would remove the driver and fill the box with poly fill stuffing from a fabric store. Try to keep it not so tightly packed in there as to impede voice coil movement. The stuffing will reduce wave formation inside the box and allow the driver to move a bit more freely, making it appear to sound a bit deeper.
Old Mar 1, 2005 | 09:23 AM
staticlag's Avatar
The Professor
Note: "PolyFill" is a loose filling, the fill I'm talking about comes in sheets and you buy it by the yard.
Old Mar 1, 2005 | 09:26 AM
staticlag's Avatar
The Professor
One more thing:
Though both subs may be only 8", they will most likely have different displacements (the coil can move further, pushing more air), and will not sound the same.
Old Mar 1, 2005 | 10:49 AM
devoid's Avatar
My doctor prescribed RX-8
if not already, use a JL audio W7 8"....this will give you some big sound...especially if ported as well.
Old Mar 1, 2005 | 11:28 AM
meticulousmobile's Avatar
"No offence, but the people working at stereo places are probably high school dropouts"
Wow, had a bad experience somewhere? (not that most aren't ) Anyways, Devoid hit it, 8w7 will be nice and warm, maybe even tingly. If you do want to keep the sub you have, definitely rebuild, ported needs a little more box volume.
Old Mar 1, 2005 | 12:21 PM
Tamas's Avatar
Registered Lunatic
Dang, two votes for the JL 8W7... mine is a Diamond Audio sub.
Wish I'd have gone with the JL... the audio store recommended the Diamond. They are a Diamond distributor so they probably get more kickback from them. The JL would have been an option but I took their recommendation. This is what not having good knowledge about the components does to you.
Hm... more money. This is getting irritating
Thanks folks.
Old Mar 1, 2005 | 03:03 PM
rXter's Avatar
Tamas -- Regardless of how it sounds that is one great application for the pass through. Very tidy and keeps your trunk pretty clear. Make it sound great and you'll set the pace for efficient use of space in the boot.
Old Mar 1, 2005 | 03:47 PM
There's nothing wrong with Diamond, you just hear more about their component sets than their subs
Old Mar 1, 2005 | 04:19 PM
SlashMatrix's Avatar
Living proof of that. I have a Diamond 10" TDX in my trunk. The box takes up a lot of space but it sounds very very good. very clean bass. Don't be disappointed you chose diamond.
Old Mar 1, 2005 | 06:15 PM
Tamas's Avatar
Registered Lunatic
I'm not really disappointed per se - as I said, I like the tight bass I have. Just in case the JL indeed does sound "warmer" I'd feel a bit disappointed.
mr. GrandGame
Sep 9, 2025 10:41 PM
uZu
Dec 30, 2015 12:35 PM
GK1707
Dec 2, 2015 10:01 AM
Mr.Durden
Aug 12, 2015 02:21 PM
RX7.9
Jul 20, 2015 12:01 PM
