How do I remove factory Exhaust tips?
Old Feb 26, 2005 | 06:59 PM
sandyolson's Avatar
1sttimeownerofRX8
Smile How do I remove factory Exhaust tips?
I'd like to have my husband replace my factory exhaust tips on my 04 RX/8 but he says he needed to remove the current ones and he can't figure out how to do that, any help?
Old Feb 26, 2005 | 07:02 PM
brothervoodoo's Avatar
RainMan is Back
I've read of people replacing the tips. If I recall, blow torch the old and re-weld the new...
Old Feb 26, 2005 | 07:03 PM
cgrx's Avatar
DRIVEN
They are welded on
Old Feb 26, 2005 | 07:06 PM
sandyolson's Avatar
1sttimeownerofRX8
[QUOTE=brothervoodoo]I've read of people replacing the tips. If I recall, blow torch the old and re-weld the new...[/QUOte
I was hoping there was an easier way, I guess I should take it to a shop, he can rebuild a VW from the frame up but he can't figure this one out, or won't.
Old Feb 26, 2005 | 07:08 PM
DARKMAZ8's Avatar
"Call me Darkman"
yep blow torch
Old Feb 26, 2005 | 07:12 PM
sandyolson's Avatar
1sttimeownerofRX8
okay, seems that blow torch is the way to go, thanx all! I will continue to check here until tomorrow, when he's out there with the blow torch!
Old Feb 26, 2005 | 09:07 PM
cgrx's Avatar
DRIVEN
You couldn't saw it off ?
Old Feb 26, 2005 | 09:17 PM
bmcc49er's Avatar
When I was polishing mine i noticed one sticks out farther then the other one. Bummer.
Old Feb 26, 2005 | 09:21 PM
RainMan is Back
I think they all do.. :o
Old Feb 26, 2005 | 10:57 PM
NoTears316's Avatar
Shock and Awe
I hope I'm not the only one thinking this.... why would you want to replace the tips? I mean, as opposed to just replacing the entire exhaust? Going for the "coffee can" look without actually gaining performance?
Old Feb 26, 2005 | 11:19 PM
cgrx's Avatar
DRIVEN
the stock exhaust could be a little bigger. If you wanted the look w/o the sound or cost - it would be the way to go. As long as it's done tastefully
Old Feb 26, 2005 | 11:31 PM
theCATALYST's Avatar
In darkness I sleep.
Remove the exhaust shrouds (be careful not to break the plastic tabs that hold them in)
Drop exhaust from rear hangers (x4) not sure if this will give you enough working room, if not remove exhaust from last hanger and cat.
Use portaban (portable ban saw) or hack saw and remove tips.
Post pics when done, I'd like to see.
Old Feb 26, 2005 | 11:55 PM
RainMan is Back
Agreed...
Old Feb 27, 2005 | 02:48 PM
sandyolson's Avatar
1sttimeownerofRX8
excellant advice
I will post the pics, he's working on it right now so he sould be finished today sometime. Thanks for the instructions!
Old Feb 28, 2005 | 02:35 PM
sandyolson's Avatar
1sttimeownerofRX8
New Tips
thankx for all your help, my hubby got the old ones off and the new ones on in less than an hour. No I don't have more power or a different sound but I don't need or want either. I just want it to look good, maybe if I were younger those things would matter but for now, it looks great.
Old Feb 28, 2005 | 02:39 PM
sandyolson's Avatar
1sttimeownerofRX8
i don't know if you can see the pics or not , i upoaded them but not sure were!
Old Feb 28, 2005 | 08:02 PM
I don't see the pics anywhere. When you post a reply, click "Manage Attachments"
Looking forward to seeing....
rotorocks
47
May 11, 2016 03:23 PM
ktec
RX-8 Show and Shine
Oct 1, 2015 11:20 PM
vssystemluba
Jul 19, 2015 04:16 PM
AussieGray
Jul 16, 2015 03:58 AM
