Did anyone do any brake upgrade?
Old Feb 23, 2005 | 10:55 AM
S-AIR's Avatar
Hi, its time for my brakes to be done and i am just wondering if any of u guys did that yet. Was thinking of just changing the discs to slotted, any comment or recommendations? Should i just stick with orignals? Something not too crazy...
Old Feb 23, 2005 | 11:10 AM
PUR NRG's Avatar
Try searching the forums.
________
126 C
Old Feb 23, 2005 | 11:46 AM
buddman's Avatar
Buddman
Sent ours in for it's scheduled oil change, brought along the service bulletin, waiting on the new brake pads for installation.
Old Feb 23, 2005 | 12:24 PM
Pete's Avatar
I did . Won't be able to tell if it worked until it warms up
Old Feb 24, 2005 | 10:16 AM
MyRxBad's Avatar
Fb's rock!
I don't think the slotted rotors will change braking much, except eat your brake pads that much faster.
But it all depends on if the car is going to see track time or not. If not I'd say keep the stock rotors on there and get some different material brake pads which will make a difference in braking. As per everything automotive, there is a trade off. See which "tradeoff" is best for your situation and go w/it.
Old Feb 27, 2005 | 07:24 PM
essentialspeed's Avatar
Essential Speed
KVR big brake kit used
Hey guys i installed the KVR front big brake kit last spring..what a difference:^)
you think you have solid brakes stock..wait until you can stand your RX8 on its nose:^)
check out my website for pics
www.essentialspeed.com
later
ps i also saved 9lbs per corner on the fronts..and the rear cross drilled save 1.5 lbs per corner
Old Feb 28, 2005 | 06:24 PM
Shogun's Avatar
I had a set of drilled and slotted Brembo discs on my last car (99 Mk4 VR6 VW). Pad life (Mintex) was average and worked good when using the brakes aggressively on the track. Sometimes the slots would fill in with pad material and the brakes would shudder under light braking. Don't see any benefit from the slots on the street.
Old Mar 15, 2005 | 09:11 PM
Sajek's Avatar
later
That's kinda scary.....I can lock up the wheels (in some conditions) at pretty high speed. I chirped my tires today breaking hard from 100km/h to 70km/h.
Temperature was around 0 deg. C so I might get better stopping power when its nice and warm but I guess I always thought the tires were the weak link in stopping our babies (by that I don't mean our tires are weak, but rather our brakes are nuts
I realize there must still be a difference though. Would be incredibly interesting to have data (braking distance from a set speed) from controlled tests with different brake setups.
Old Mar 16, 2005 | 04:09 PM
Hellbreed's Avatar
Slotted rotors just look good! But I would keep stock for the street, especially at about $350 a pair. The Brembo kit would be sweet though!
http://www.mazdatrix.com/8brakes2.htm
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Oct 3, 2015 09:51 AM
D13
Oct 1, 2015 07:55 AM
Quiggs321
Sep 30, 2015 05:34 PM
