what size am i looking for
Old Feb 22, 2005 | 06:37 PM
veilsidev1's Avatar
what wheels will fit the stock tires. I want to buy some wheels from wheelsdirectonline.com and have sizes such as 18x8 18x9 ect. And what is the bolt pattern, or in other words, which ones will it be compatible with, thanks
Old Feb 22, 2005 | 06:50 PM
Sociopath's Avatar
SocioPath
18x7, 18x7.5, or 18x8 size wheels will fit stock tires
Bolt pattern is 5 x 114.3
However, you have to consider the right offset, so the wheels do not stick out too much
Do a search in the forum, plenty of info.
Old Feb 22, 2005 | 07:08 PM
veilsidev1's Avatar
great, but which one would be the best fit, in other words, which one would you go with, thanks alot for the info.
Old Feb 23, 2005 | 08:55 AM
IJM's Avatar
IJM
Red
Look on www.tirerack.com at the tyre specs for the size and model of tyre you're interested in and look at the "Rim Width Range" column. This is the size of rims that that tyre will fit.
Here's a direct link for Tire Specs for Bridgestone Potenza RE040
If, after you've followed the link, it says the the query has expired, just hit Refresh.
Hope this helps.
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
nferguson88
Oct 6, 2015 12:45 PM
GK1707
Sep 27, 2015 07:33 PM
