Check Oil Appearing...
Old Feb 18, 2005 | 12:04 AM
C-Mac 18's Avatar
has anyone experience their Check Oil light flashing? what happened to me was everytime i start it up after work that the check oil is appearing.. then in a few minutes if its not too cold outside it will disappear.. but sometimes it takes longer.. recently im experiencing, at the middle of my drive, the check oil is gonna flash but then it will go out again... what do you think bout' this fellas??..
Old Feb 18, 2005 | 12:30 AM
sferrett's Avatar
Whaaaa?
Have you checked the oil level? The car uses oil by design so you need to check it and top it off somewhat regularly.
If the light's coming on and the oil level is at the full mark on the dipstick, take it to the dealer as the oil level sensor could be malfunctioning.
If the oil is low, add oil until it's full and read your owner's manual.
Old Feb 18, 2005 | 12:36 AM
markd's Avatar
Lawyer in training :)
C-Mac--How long since your last oil change? On average, the 8 uses about a quart of oil about every 3,000 miles, so if you don't check your levels every so often when you get gas, that light will become a familiar occurrence. Unfortunately, the 8 is probably the only car in the world that really does need to have its oil changed that often.
I'm bad at checking my oil, and that light comes on near oil-change time every time. Like your situation, the light goes away after I drive a short distance, but it comes back on next time I start the car. Keep an extra container of non-synthetic 5w20 in your trunk for safe measure.
Old Feb 18, 2005 | 07:31 AM
HELAS's Avatar
Kal-El Is The One
Ya this has happened to me but my oil was low. Check your level and add oil accordingley. If no change, SEE YOUR DEALER! Good luck
Old Feb 18, 2005 | 08:57 AM
Elara's Avatar
Check your build date too. This happened to me before they replaced my oil pan. It was really annoying- I'd check the oil, and the light would STILL come on intermittently. If your oil level is okay, and you have an earlier build date (before December 2003, I think) you may need the oil pan replaced.
Old Feb 18, 2005 | 09:25 AM
StewC625's Avatar
Insanely Yellow
Call me goofy, but I'm guessing you need to check your oil with the dipstick, and most likely add more.
But, that's just me.
Seriously, you should check your oil at least weekly with this car, and add enough periodically to keep the oil at the "full" mark at the dipstick. I add about 2 oz of oil every other week.
Old Feb 18, 2005 | 01:33 PM
Elara's Avatar
I'm still going to assume the obvious that you DID check your oil level. I think it'd be pretty dumb for someone to post this without checking it first- that should just be the obvious answer. I took this to be "it's not low and it's still coming on." If that's the case, you may need to have the oil pan replaced. there's a TSB out for the earliest versions- the sensors in the oil pan didn't work as they should have and gave false indicators all the time- like mine did.
Old Feb 18, 2005 | 03:34 PM
StewC625's Avatar
Insanely Yellow
Also, a loose wire to the sensor will do that. I read on a thread that someone had hit a chunk of debris on the road and that caused the sensor wire to go intermittent and the check light to flicker.
Old Feb 18, 2005 | 04:11 PM
Berni's Avatar
Wants an 8 again
i had a phantom light a 4.2k or 5.2k rpms after a few seconds but never when starting or sitting. oil pan sensor to include oil pan was swapped all warrenty. was a thread about it awhile ago.
Old Feb 18, 2005 | 04:43 PM
C-Mac 18's Avatar
thanks for all the feedbacks... too be honest with you all... i had this car since last August and I havent check my oil at all... i didnt add or even check it like i said, cuz the gauge is always been halfway or in normal condition... its just that when the winter time comes thats when i started noticing it... alright thanks all...
Old Feb 18, 2005 | 04:52 PM
BlueEyes's Avatar
Dude, you gotta take care of your car. I don't even have a rotary car and I check my oil every couple fill ups. If you need help on how to check the oil just ask and we will be more than happy to give you some advice.
Old Feb 18, 2005 | 05:09 PM
StewC625's Avatar
Insanely Yellow
Didn't the dealer tell you at delivery that the car uses oil as part of it's design and that you need to check it regularly?
Also the gauge has nothing to do with the quantity of oil until the oil pressure starts dropping from lack of oil. If that's happening, you've already likely damaged the engine.
Old Feb 18, 2005 | 05:12 PM
Overport's Avatar
Overport
if your car was built before December '03 it may be caused by the defective oil pan. So when you fill it up to spec, the light still comes on. It can get really annoying.
Old Feb 18, 2005 | 07:16 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
C-Mac... oil level in any automobile is one of the most basic things. You always need to periodically check your level and get regular changes to make sure you keep everything running properly. Don't rely on your car to tell you when something goes wrong! I hope you picked up on everyone's good advice from the above posts...
Old Feb 19, 2005 | 12:34 AM
C-Mac 18's Avatar
im planning to bring my 8 to the dealer tomorrow for check up.. my car is at 3200 Miles right now and hasn't change oil yet... they advised me to change it at 5000m so i followed... did u have your first oil change at 5000m?.. so i guess all of you are putting extra oil if needed..like i said in my case im not checking my oil regularly and the only way for my oil to be change or to be check is when i will bring it for an oil change once the mileage is reached.. also im in the Blue8 Team and lives here in Chi-town... just give some advise or things that u think i should consider you know... big thanks...
Old Feb 19, 2005 | 01:47 AM
dazygirl415's Avatar
check your own oil. i'm a chick and i learned how to do it. look in the manual if you need help.
Old Feb 19, 2005 | 02:13 AM
realdeal's Avatar
Please check your oil level ASAP. If your engine locks up its your fault and won't be covered under warranty. Rotaries need oil, and your should check it every 1000miles.
Old Feb 19, 2005 | 02:14 AM
jenkins-crew's Avatar
Do you add any oil every 1000 miles? I add about a quart every 1000........
Old Feb 19, 2005 | 02:18 AM
C-Mac 18's Avatar
No I haven't add anything at all and its 3400 m now already.. i'll do that tomorrow and hopefully it wont illuminate at all...
Old Feb 19, 2005 | 02:21 AM
realdeal's Avatar
I usually add a quart after 1000-1500 miles. Lately since its been so cold I've been really bad about it, but I keep 2 quarts in the trunk just in case.
Old Feb 19, 2005 | 02:24 AM
If you don't know how to check your oil then your not a rotory owner :D :D
Old Feb 19, 2005 | 02:27 AM
C-Mac 18's Avatar
yeah man... ur right..haha.. but im learning now man...
Old Feb 19, 2005 | 02:29 AM
realdeal's Avatar
Hey welcome to the club.
Old Feb 19, 2005 | 02:32 AM
C-Mac 18's Avatar
thanks man... yo'all peeps here are very helpfull... big upps...
Old Feb 19, 2005 | 02:34 AM
someone earlier said one quart every 3k miles and i thought that was stretching it. i add every 1200.
