question about tire sizes
Old Feb 16, 2005 | 10:36 PM
Iwannarex8's Avatar
I was doint some research and wanted to know why is the overall diameter the same on these 2 tire sizes I thought the middle number represented the distance between the rim and the outer tread of the tire, is this a typo or is this the way it is??
Im a little confused.....will both of these tires look equal or will the fronts look taller from rim to tread??
Toyo
Proxes T1s
Weight: 24.3lbs.
overall diameter 25.4
Toyo
Proxes T1s
Weight: 22.7lbs
also they didnt have 265/35/19 or 235/30/19 or 225/35/19 or 225/30/19.....
wheres a good place for tires other than tirerack........I already know about them but some other places for price comparisons and brands?
Old Feb 17, 2005 | 02:26 AM
Fanman's Avatar
I got mine from www.edgeracing.com. What's cool about them is they have the weight of the tires too. They had the best price on the Toyo T1S, and their service was very good.
Old Feb 17, 2005 | 02:58 AM
Iwannarex8's Avatar
thats where I got those specs I posted
I wanted to go 225/35/19 for front then 265/35/19 for back but they have neither size
then I said ok 225/30/19........they dont make it
then 235/30/19 (they dont make it/have it)to match with 265/30/19
so when checking diameters I noticed that the 235/35/19 were the same as the 265/30/19..........just wondering if the tires will look equal on the front and rear rims or will the front(35) look thicker than the rear(30)??
Old Feb 17, 2005 | 05:43 AM
RX4life's Avatar
correct me if im wrong but .. the sidewalls on 225/35 and 265/35.. are not the same.. the 225/35 the sidewalls will be really low in profile.. and the 265/35 will be like buying a 225/40 i believe.. so your car would be kinda off..235/35 and 265/30 would be a good combo. i think
Old Feb 17, 2005 | 05:46 AM
RX4life's Avatar
Toyo
Proxes T1s
Weight: 24.3lbs.
Toyo
Proxes T1s
Weight: 22.7lbs
the middle number you are talking about is the % of the first number ... when you say 225/35 it means the sidewall is of the tire is 35% of the 225
so as i said in my previous post.. if you get a 225/35 then you must try to get a lower percentage tyre for the fatter rears..say 265/30 because a 265/35 is the same as a 225/40 or 45 not sure..
Old Feb 17, 2005 | 11:18 AM
Fanman's Avatar
RX4life is correct. A 35 series tire on a 225 will look taller than a 265 tire. You should be looking for 235/35/19 & 265/30/19.
Old Feb 17, 2005 | 02:18 PM
IJM's Avatar
IJM
Red
A handy tool:
U.S And Metric Tire Size Information Calculator
ladnarf1
Apr 29, 2021 11:53 PM
rx8inator
Sep 1, 2015 07:18 PM
Shinka84
Aug 19, 2015 04:55 PM
GK1707
Aug 3, 2015 10:23 PM
