Clear Corners Flare Out?
Old Feb 8, 2005 | 04:29 PM
salituro64's Avatar
Does anyone have a close up picture, or can someone possibly explain what I read in another post - the clear corners are not flush like the OEM lenses and they flare out a little. I can't imagine where they would flare out since the OEMs are perfectly flush.
Old Feb 8, 2005 | 04:53 PM
jenkins-crew's Avatar
yes they flare out a little in one spot but it still looks clean. It is just a small smooth bump like flare. Trust me nothing to worry about. Why the concern?
Old Feb 8, 2005 | 05:01 PM
Here you go.
Attached Thumbnails Clear Corners Flare Out?-p1010038.jpg   Clear Corners Flare Out?-p1010041.jpg
Old Feb 8, 2005 | 08:23 PM
salituro64's Avatar
Thanks for the pics. My concern was that they flared out more in the front or rear of the lens. From the pics I can see it flares out in the middle. That's cool. Where did you get yours? Did you install the stealth bulbs? Also did you remove that foil that I heard people have removed because it looks better? Sorry for all the ??, but I like to do my homework before I add cosmetic cahnges. I love the way the car looks already.
Old Feb 8, 2005 | 08:48 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
There is a DIY somewhere here on the forum that explains how to do that install. I always thought that those particular clear corners were not flush because they were "aftermarket", and not Mazda-factory parts.
I cannot confirm, but I always assumed that the Japan-spec 8's had flush clear corners.
Old Feb 8, 2005 | 11:39 PM
No problem man. I got mine from rotaryextreme.com for $75 w/stealth bulbs. Then I got tired of the orange so I switched to the 5 led bulbs from ctlumination.com and yes I did remove the foil piece. It was a pain but well worth it. Hope that helps!
Old Feb 11, 2005 | 04:35 PM
miraclewhip's Avatar
what foil piece are u talkin about
Old Feb 11, 2005 | 06:34 PM
Sold on Rotaries!
Look up clear corners in the DIY section of the forum.
Old Feb 11, 2005 | 07:14 PM
slllygrl10's Avatar
EX-Member
He meant the reflector inside.
Old Feb 11, 2005 | 07:17 PM
slllygrl10's Avatar
EX-Member
Yes, all after market clear corners flare out exactly like the pics.
Old Feb 11, 2005 | 07:43 PM
yeah the metal reflectors inside.
Old Feb 12, 2005 | 09:19 AM
salituro64's Avatar
What purpose does the reflector serve and why is it better with it removed?
Old Feb 12, 2005 | 11:41 AM
Well if you leave it in it keeps all the light to the front of the side marker. Most people take it out because then it fills up the whole side marker with light and looks better. It is all personal preference.
Old Feb 12, 2005 | 12:09 PM
JoeMamma's Avatar
Where the air is rare
I just installed the JDM clear corners with Mazda part numbers, and they have the same flare to them. Why? I dunno. They really look nice though. I used LED amber bulbs, and popped out the reflector nonsense inside, too.
Old Feb 12, 2005 | 02:49 PM
yep the clear corners are genuine mazda parts!
Old Feb 12, 2005 | 02:59 PM
Mr. Ed's rx-8's Avatar
no more 8
thats one of the first things i need to do when i get my car back...get that little metal piece out of there.
Old Feb 14, 2005 | 10:57 AM
ROTRYPWR's Avatar
when websites say a "harness" is included with the clear corners, what does a harness mean??? And when u install the clear corners, do u have to remove the inside wheel fender, or is there a easier way like just popping the clear corner out with flathead???
THX for the help
Old Feb 14, 2005 | 11:21 AM
You don't need a harness, you can use the factory one. Just remove, I think it is, three screws from the fender well, the one from the side marker lens, pop out the lens, remove the bulb/disconnect harness. Then attach the bulb/harness to the new lens and reverse the process. Really only takes 5 mins if you don't remove the reflector inside. If you descide you want to remove the reflector do it in the house before you start. Hope that helps!
Old Feb 14, 2005 | 01:14 PM
salituro64's Avatar
How do you remove the reflector?
Old Feb 14, 2005 | 01:43 PM
Tamas's Avatar
Registered Lunatic
With a flathead screwdriver and some needle-nosed pliers.
Old Feb 14, 2005 | 04:59 PM
That'll do it!
This might help:
https://www.rx8club.com/series-i-do-yourself-forum-73/diy-side-marker-clear-corner-lights-installation-10379/
Old Feb 15, 2005 | 01:52 PM
the reason why they flare out is for aerodynamic purposes...haahai think it looks cool
Old Feb 18, 2005 | 03:06 PM
I don't know why they did that looks good to me either way.
Hunterkelley24
Series I Engine Tuning Forum
Jun 14, 2022 08:32 AM
Digitz0070
Oct 7, 2015 12:43 PM
duworm
Oct 1, 2015 04:57 PM
GK1707
Sep 27, 2015 07:33 PM
Stubbs
Sep 27, 2015 04:06 PM
