Will this sound good?
Old Feb 2, 2005 | 06:32 PM
Redlinin 8's Avatar
Hey guys im installing 2 12' kicker cvr's with a alpine mvr-f900 amp.I dont know too much about speakers and amps so im wondering will this setup sound good? the info on the speakers and amp are below:
Subs:
CVR12
Outer Frame Diameter, in (cm) 12 1/2 (31.8)
Nominal Impedance [Zn], ohm [per coil] 2 or 4
Power Handling Watts, Peak (RMS) 800 (400)
Sensitivity [SPLo], dB @ 1W, 1m 86.7
Effective Frequency Range, Hz 25-500
Mounting Depth, in (cm) 6 3/16 (15.7)
Hole Cut-Out Diameter, in (cm) 11 1/8 (28.3)
Equivalent Volume [Vas], ft3 (L) 3.37 (95.37)
Net Displacement, in3 (cc) 122.1 (2001)
Moving Mass [Mms], oz (g) 5.52 (156.4)
Magnet Weight, oz (kg) 47.05 (1.334)
Amp:
Power band width 400W + 400W (0.3%THD, 20Hz – 20kHz, 14.4V, at bridge connection into 4Ω) / 200W × 4 (0.3%THD, 20Hz – 20kHz, 14.4V, at 2Ω) / 100W × 4 (0.08%THD, 20Hz – 20kHz, 14.4V, at 4Ω)
Frequency characteristics 20Hz – 50kHz (+0, -1 dB)
S/N Ratio 105dBA
Input sensitivity 500mV – 8.5V / 10kΩ, [Center] 1.0V / 10kΩ
Crossover frequency 50 – 200Hz, slope: 12dB/oct
Size (W x H x D) 650 x 86 x 247/300 mm
Weight 15 kg
Old Feb 3, 2005 | 12:05 AM
Praga's Avatar
Cant comment on the amp, but the CVR's are cheese. The L5's and moreso, the L7's are nice though.
Dokuji
Nov 1, 2016 02:51 PM
Kanthinar
Dec 21, 2015 01:24 PM
GrAfiX
Aug 24, 2015 08:08 AM
dbarber
Jul 25, 2015 01:34 PM
ironj221
Jul 16, 2015 10:16 PM
