Sway Bars
Old Jan 24, 2005 | 09:05 PM
ROTRYPWR's Avatar
Sway Bars
Which sway bar is best according to the more knowledgable rx-8 drivers?
The Mazdaspeed : [front] 27.3 mm
[rear] 17.3 mm
Racing Beat : [front] 32.0 mm
[rear] 19.0 mm
Tanabe : [front] 30.4 mm
[rear] 20.0 mm
So which one would you guys go with?
Also does thicker sway bars mean better?
Thx
Old Jan 25, 2005 | 09:35 PM
ROTRYPWR's Avatar
Doesnt anybody know which one is the best sway bar???
WHat would ppl go with if u had a choice???
Old Jan 25, 2005 | 09:37 PM
Fanman's Avatar
I went with Racing Beat & I love them. Handling is much more benign now.
Old Jan 25, 2005 | 10:01 PM
blksf8's Avatar
^^^what he said. RB front and rear sway bars here.
Old Jan 25, 2005 | 10:10 PM
sohcpunk's Avatar
I think majority of the people here got the Racing Beat sway bars. I went with the Tanabe's because #1 They are a reputable japanese tuning company, # Their bars are hallow which greatly reduce the weight of the car ( Racing Beat's are solid steel) #3 With a bigger rear sway bar and smaller front sway bar, that will give the car a slight oversteer which is great if you are an experienced driver. I personally think the Racing beat bars are too overweight and have understeer which I dont like. Its all up to your preference in driving styles. I have the Tanabes and it got rid of the car's body lean almost completely.
Old Jan 25, 2005 | 10:40 PM
Kurt Bob's Avatar
I went with Racing Beat bars along with their springs. I love the handling, but can't compare them to any others out there. From experience though, the minute differences between different companies' bars don't mean much. It's the step up in size from the OEM bars that you really feel.
Old Jan 26, 2005 | 12:26 AM
ROTRYPWR's Avatar
Do the racing beat sway bars get rid of the leaning when cornering in the rx-8????????
Old Jan 26, 2005 | 12:35 AM
StealthTL's Avatar
Metatron
Have you even been to the RB site?
What a knuckleheaded post - "...I went with Tanabe because they are lighter, Racing Beats' bars are solid..." A 32mm solid bar wouldn't flex at all!
Have you even looked at the RB site? It clearly states the wall thickness is 0.1875" front and 0.125" rear.
Hollow, right?
Or "hallow" as you say the Tanabes' are.
How do YOU spell hollow?
S
sohcpunk's Avatar
There are differences. Like i said, the Tanabe bars are hallow and lighter. The size of the bars is difference giving the car a more neutral/bit oversteer characteristics. All bars will reduce body roll as long as it in larger than the stock diameter bars. The springs from Racing Beat are a bit too soft for my liking. A higher spring rate would be better for cornering. I went with the Tein S-tech springs
Old Jan 26, 2005 | 12:49 AM
sohcpunk's Avatar
Thanks for being an *** just cuz I can't spell. I didn't say anything about flexing. You should read my statement carefully before you do any bashing. I can assure you that I probably know more about suspension and go to a better school than you do. So back off
Hollow, right?
S
Old Jan 26, 2005 | 03:04 AM
Fanman's Avatar
So what are you saying ? That the RB sway bars are not hollow (by your definition) ? How exactly are you sure that the Tanabes are lighter ? Have you weighed both of them ? As far as I know when I put them on they were very light as the RB units are hollow as well (not solid).
The wall thickness makes a sturdy bar. If you have felt the stock bar it felt flimsy in comparison and easily flexible/bent.
Old Jan 26, 2005 | 05:21 AM
RotorManiac's Avatar
Absolute Rotary Madness
MS sways here. Its the most 'stock like' setup, with a little bit less body roll. Sways are light and stiff and almost same diameter as stock.
Depens on what you want: if you keep stock shocks go with thick sways, if you plan on getting adjustable coilovers, then I think the MS is the way...
Old Jan 26, 2005 | 09:16 AM
brillo's Avatar
Go Texas Longhorns!
Asking whats best depends on several factors.
The MS and racing beat sways were designed to compliment the rest of their respective suspension kits, for example, the MS bars are not as thick as the RB but thats b/c Racing Beat only replaces the springs and sways, therefore, they have to work in the confines of the stock shocks, while my MS replaces everything so the bars are not as thick as the new spring/shocks assist in controling the roll.
If your just going to get stand alone sways, that is, your not getting springs, I would get the RB setup. But if you are going to lower the car, I would try to get a matched set (springs, sways and shocks), who ever you go with.
Old Jan 26, 2005 | 11:57 AM
sohcpunk's Avatar
Thats exactly what I am saying. The Racing Beat sway bars are solid steel. Contact Jim Langer if you don't believe me. Regarding the weight differences, it is a no brainer, a hollow bar will be lighter than a solid bar. They are both made of steel. Yes I have felt the stock bars. They are thinner so they are more flimsy. Its all common sense.
Old Jan 26, 2005 | 12:14 PM
StealthTL's Avatar
Metatron
Serenity now......Serenity now......
Thats exactly what I am saying. The Racing Beat sway bars are solid steel. ....... a hollow bar will be lighter than a solid bar. They are both made of steel. ......Its all common sense.
I give up, he's right, they are made from old ships anchors, for extra weight.
S
Old Jan 26, 2005 | 07:40 PM
Kurt Bob's Avatar
In answer to the last "serious" question, the RB sway bars take away almost all of the leaning. And, I'd like to add one general comment about Racing Beat: They have been in business for a long time. I have personally dealt with them for 22 years. Most of their equipment is meant for the enthusiast who doesn't want to make his or her car "unstreetable." The modifications are meant to enhance the car and not change the character (unless they tell you it's a racing part). I find that their exhausts and suspension kits do just that - add to the enjoyment without much sacrifice in road manners.
I hope this helps!
Old Jan 26, 2005 | 08:36 PM
typerr's Avatar
still plays with cars
Thats exactly what I am saying. The Racing Beat sway bars are solid steel. Contact Jim Langer if you don't believe me. .
Uh, the racing Beat bars are definately hollow (I own the front bar) and very light but to be honest, comparing the weight of sway bars as a basis for purchase is a little silly. Do you really think a couple pounds makes a difference you can feel on a 3000 pound car?
Old Jan 26, 2005 | 08:49 PM
staticlag's Avatar
The Professor
As soon as I get enough money, I'm going to buy these:
http://www.specr.com.sg/rx8autoexe.html
The front/rear sway bars, sports stabilizer bar, and chassis braces coupled with the MS spring and shock kit look likes a serious suspension upgrade to me :D :D :D :D
Old Jan 26, 2005 | 10:21 PM
Kurt Bob's Avatar
Well said. The Racing Beat bars are hollow (tubular), as stated clearly on their website. However, hollow bars are not used just to save weight. They are much stronger (stiffer) than a solid bar.
Old Jan 26, 2005 | 10:34 PM
staticlag's Avatar
The Professor
Then why aren't crow bars hollow?
Old Jan 26, 2005 | 10:51 PM
typerr's Avatar
Because the hollow crow bar would need to have a larger outside diameter to acheive the same stiffness.
Light weight is usually not a concern for crowbar designers. :D
Old Jan 26, 2005 | 11:25 PM
LiL BenNy's Avatar
Bubblicious? DEF.
whats under and over steer lol..
Old Jan 27, 2005 | 02:52 AM
Spin9k's Avatar
Momentum Keeps Me Going
Would anyone care for a little science in this bizarre discussion?
Try this on solid vs. tubular sways: http://www.whiteline.com.au/docs/bul...%20Swaybar.pdf
Old Jan 27, 2005 | 11:26 AM
Rx7Roadster's Avatar
My spoon is too big
Hollow bars are not stiffer then solid bars. But, removing the center section of a bar does not reduce its stiffness greatly and removes much of its mass. This is the reason they are hollow. The benifit of weight savings greatly out weighs the loss of stiffness.
