RX8rider
01-24-2005, 02:42 PM
This may be a silly question but I was wondering why the wax layer/coating that we put on doesn't melt off in the summertime when the temps are high, sun is shining, and the surface of the car is scorching?
View Full Version : Why doesn't the wax melt? RX8rider 01-24-2005, 02:42 PM This may be a silly question but I was wondering why the wax layer/coating that we put on doesn't melt off in the summertime when the temps are high, sun is shining, and the surface of the car is scorching? PUR NRG 01-24-2005, 03:40 PM Point in fact is the wax does melt. That's why it loses half of its effectiveness after one month. Most waxes also blend silicon oils for increased shine, which tends to attract dust. Overall it doesn't seem like a very effective solution. Zaino lasts longer than traditional waxes but requires multiple coats. ________ Rhode island medical marijuana dispensaries (http://rhodeisland.dispensaries.org/) rodmeister 01-24-2005, 03:41 PM Because the coating is too thin to run. You can put a coating of a liquid like kerosene on a car - it will evaporate but won't run off. Try putting a wax-thin coat of oil, it simply won't run off since there isn't enough to produce the surface tension necessary to drip. PUR NRG 01-24-2005, 04:41 PM Capillary action means it won't run but it will melt. Imagine that thin layer of wax. When it gets warm it melts and dirt sticks to it. The dirt absorbs some of that wax and takes it away when the dirt is washed off. ________ Home made vaporizer (http://homemadevaporizers.info/) Labop 01-25-2005, 05:57 AM no wonder the dirt around my driveway always looks shiny... :) misterwilson007 01-25-2005, 10:48 AM all waxes have different hardnesses and different melting points. Both of these physical properties affect the lifetime of the wax........ |
