Cleaning Plastic off the Muffler
Old Jan 20, 2005 | 01:32 PM
JonsToy's Avatar
Registered Rep
This is one of those minding-your-own business stories The other day I was following a garden center delivery truck when a large piece of plastic blew out of his truck bed and into the roadway. Though I tried to evade it, I ended up driving right over the top of it. I kept looking in the rearview to see it behind me, but it got caught up under the car, so I pulled over after about a block or so to pull it out myself. The plastic had just sort of spot-welded itself to the muffler, and with a gentle tug, I freed the connection and was on my way. My problem is that burning plastic smell. Each time I have driven the car since the incident, it smells like I'm parked next to a dry cleaning operation. My question is this- should I just let the muffler burn the plastic away, or should I try to clean it off a cold muffler with some sort of solvent I'm concerned a solvent might produce a fire hazard when the muffler heats up again!
By the way, I'm a new owner of a previously-owned, Velocity Red '04 with 10.5K miles. I spent a great deal of time researching the RX-8s before I bought, and this website was invaluable in terms of practical information about the vehicle and the entire ownership experience. Keep up the great work!
Old Jan 20, 2005 | 01:39 PM
Wankeler's Avatar
zoom freaking zoom
Not sure you'd want to use any kind of solvent... I'm sure it'll all evaporate long before the exhaust gets up to temp.... but still. When I was a technician and we had people run over plastic bags the quickest way to remove the "residue" of plastic was with a wire wheel. I've found that a BRASS wired wheel doesn't harm the surface of the exhaust system like a steel one does. Go find yerself a brass wire wheel for your drill and you're good to go.
Old Jan 20, 2005 | 03:15 PM
Stone's Avatar
Stone
Good luck trying to scape that stuff off, once it melts/burns on it is almost like a unbreakable weld, I had that happen to me once and sort of grinding it off, theres not much you can do but let it burn off. I just taked up and went on a few nice long drives and it finaly went away took about a week. Sorry dude that sucks.
Old Jan 21, 2005 | 12:54 AM
yea i had a something like that happen to me. i have not done anything about it. just smells bad. think it might be and excuse to buy a new exhaust.
Old Jan 21, 2005 | 01:16 AM
RotaMotion's Avatar
Felix the Wankel!
If you don't have a wire wheel, maybe a straight edge razorblade in one of those hand holders. I've had really good luck over the years scraping all sorts of Cr@p with one of those things.
Also found this:
Plastic Melted on Surface
Removing Burnt Plastic from your Toaster
Curiously, I've seen a couple of references to finger nail polish remover, which I think is just Acetone.
Shankapotamus3
Mar 14, 2021 03:53 PM
MolecularConcept
11
Sep 29, 2015 09:21 PM
XianUnix
Sep 29, 2015 03:48 PM
drlubell
Sep 26, 2015 11:58 PM
