tech bulletin interpretation, please
Old Jan 15, 2005 | 04:01 PM
V_for_velocity's Avatar
One more couldn't hurt
From: Saskatoon, SK -- go to Winnipeg then head west
This is from a Mazda tech bulletin:
"Ideally, the engine coolant temperature gauge needle should reach the middle of the normal operating range before shutting off the engine."
What does that mean, about 10 o'clock? Please excuse my stupidity.
Old Jan 15, 2005 | 05:16 PM
Omicron's Avatar
Yes, about the 10 o'clock position. This takes about 5 minutes of driving in my car.
Old Jan 15, 2005 | 05:34 PM
cgrx's Avatar
DRIVEN
could take longer depending on climate
Old Jan 15, 2005 | 05:35 PM
Go48's Avatar
Depends on what Mazda considers the NORMAL OPERATING RANGE. If it is from zero to just near halfway point, where the needle ususally parks with the engine is fully warmed up, then the MIDDLE OF THE NORMAL OPERATING RANGE would be a point halfway between those two points. However, if in the Mazda jargon the NORMAL OPERATING RANGE is zero to somewhere just short of the top reading on the gauge (which would presumable indicate overheating), then around the MIDDLE would be the middle of the gauge.
In any case, for what it's worth, I let the needle on my temp gauge reach the point where it usually parks with a fully warmed engine before stressing the engine. I think the sensor associated with this gauge is measuring the water temperature, which would not necessarily be an indication that the engine oil is at the best operating temperature for lubricating the engine components and for the oil injection nozzles.
gwailo
May 14, 2024 06:57 AM
OnebaddRx8
Oct 17, 2015 10:05 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
Tyblat
9
Aug 6, 2015 10:43 AM
