DSC flashing fix - redo?
Old Jan 13, 2005 | 06:30 PM
RX8 JET's Avatar
Unhappy DSC flashing fix - redo?
Over the Christmas break, I accidently drained the battery (left the trunk open...d'oh! ). As you know, the once the battery was recharged, I got the flashing DSC light. As per manual, I needed to turn the wheel full right, then left after key was set to start. Unfortunately, I had already started the car to run it around a short while since it was stored.....but the light went out while I was driving around.
Because I did not really turn the wheel the proper "full" manner, is the system not poperly reset?
Old Jan 13, 2005 | 06:32 PM
zoom44's Avatar
do the procedure anyway to make sure.
Old Jan 13, 2005 | 09:38 PM
RX8 JET's Avatar
Should I disconnect the battery to have the DSC flash again and then redo the procedure?
Old Jan 14, 2005 | 06:25 PM
beachdog's Avatar
I don't have the manual handy right now. There are actually a couple of resets necessary after the battery is disconnected. Look for the reset instructions for the steering angle sensor too which involves a full left and a full right turn as I recall.
Old Jan 14, 2005 | 08:34 PM
RX8 JET's Avatar
From what I read in the manual, what you described was how to reset the DSC....at least from my understanding....
Old Jan 14, 2005 | 10:07 PM
rx8cited's Avatar
Senior Member
You got it!
D13
Oct 1, 2015 07:55 AM
Danield97
Sep 30, 2015 05:59 PM
Stubbs
Sep 27, 2015 04:06 PM
drlubell
Sep 26, 2015 11:58 PM
Evan Gray
Sep 26, 2015 12:30 PM
