Corrosion OEM Strakes
Old Jan 9, 2005 | 03:33 PM
alphapenguin's Avatar
SEMPER UBI SUB UBI
I noticed that my side strakes seem to have some corrosion forming. Does anyone have any suggestions on what to do? I assume I could repolish it, but how would I continue to protect it?
Old Jan 9, 2005 | 04:12 PM
philodox's Avatar
Rangers Lead The Way!
Well, if you live in an environment where it snows, there will be salt on the roads. The aluminum fender strakes will corrode if you don't keep them clean all the time. Here is what I did.
I removed the stratkes. Using a dremel tool, I polished them to a high shine. That took all of 15 minutes for all the them. Once I was done shining them, I got some finishing spray (clear coat) and painted them. You can get a clear gloss at any paint store. It will help keep the salt off the aluminum and they will stay shiny. So far so good. I hope that helps.
Old Jan 9, 2005 | 05:39 PM
magixpuma's Avatar
umm sorry but aluminum doesnt i rust!!! am i wrong?
Old Jan 9, 2005 | 05:42 PM
philodox's Avatar
you are right, it won't rust.. but salt will still corrode and eat away at it.
Old Jan 9, 2005 | 08:01 PM
SEMPER UBI SUB UBI
it doesnt rust, but it does corrode. Sometimes if you see little white bumpy lines, its referred to as "filiform corrosion." I am not sure if I spelled that right, but regardless, thanks philodox. I'll try that next weekend.
Old Jan 9, 2005 | 08:09 PM
philodox's Avatar
No problem. Just remember to use very light coats othewise it'll look like an orange peel.
Old Jan 9, 2005 | 08:27 PM
irish8's Avatar
Get in ma belly!!
philodox is on the money!! I would also recommend, once fixed and back on the car you clean them on a regular basis. Also, add some wax to them when you clean them.
Good luck!!
- Irish
Old Jan 9, 2005 | 08:34 PM
red_rx8_red_int's Avatar
It doesn't rust, it pits. It does corrode. I also say thanks to philodox and will try it.
Old Jan 9, 2005 | 08:36 PM
philodox's Avatar
No problem guys, my pleasure to help. I did it to my fender strakes about 2 months ago and have had no problems with the clear paint flaking or chipping.
Old Feb 22, 2005 | 05:06 PM
brothervoodoo's Avatar
RainMan is Back
But can you top this.....
I didn't think so!!!
Old Feb 22, 2005 | 05:10 PM
philodox's Avatar
my god
Old Feb 22, 2005 | 05:35 PM
Outlaws eXtreme's Avatar
2010 Prius - Miss the 8
What was that, acid spilled on it?
Old Feb 22, 2005 | 05:41 PM
RainMan is Back
The Brits have some vile weather over there!!! :o
Rotary Rasp's Avatar
503wtq Boosted Bimmer
It helps if you wash your car yearly.
Old Feb 22, 2005 | 06:09 PM
Mugatu's Avatar
Even My Dog Searches
ewwwwwwwwwwwwwwwwwwwwwwwwwwwww
get replacements immediately
Old Feb 22, 2005 | 06:50 PM
mikeb's Avatar
100% Italian
LOL
they better hold up for 200.00
Old Feb 22, 2005 | 08:06 PM
Air Force RX8's Avatar
Who Cares?
Wow, makes me glad I am on the DLS Customs list for the non-metallic strakes! OOOOOHHHHH I can't Wait!!!
Old Feb 22, 2005 | 11:45 PM
SEMPER UBI SUB UBI
yah mine are getting bad, time for a buff'n. what kidna of coating do you put on it after you polish it?
Old Feb 22, 2005 | 11:56 PM
jenkins-crew's Avatar
buy the fiberglass ones....tadaahh, no corosion.
Old Feb 23, 2005 | 11:33 AM
philodox's Avatar
I use a clear gloss spray paint to put on my strakes. That way they always stay shiney, and I don't have to worrya bout corrosion. Been almost a year with no issues or flaking.
Old Feb 23, 2005 | 08:40 PM
salituro64's Avatar
Wouldn't polishing and waxing them also protect the finish? I wonder why Mazda didn't make them chromed or stainless.
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
TotalAutoPerformance
Vendor Classifieds
12
Oct 17, 2018 09:00 AM
Quiggs321
Sep 30, 2015 05:34 PM
wayloco
Sep 1, 2015 09:03 PM
