Oil pressure gauge question
Old Jan 9, 2005 | 01:48 PM
WillErickson's Avatar
Hello all, just wondering if the oil pressure gauge on the RX-8 is a true pressure gauge, or an idiot "on/off" gauge? (I tried the search, but couldn't find any relevant threads).
Will
Old Jan 9, 2005 | 01:56 PM
Nemesis8's Avatar
Bigus Rotus
It's an idiot light disguised as a gauge.
Old Jan 9, 2005 | 02:17 PM
Thanks, that's what I figured.
Old Jan 12, 2005 | 01:33 PM
Mat's Avatar
Mat
Is it possible to change some kind of sensors to transform it in an actual gauge? Assuming there is actually a sensor connected to it
Old Jan 12, 2005 | 04:09 PM
Gord96BRG's Avatar
Nope. There is an actual sensor, but it's wired to the ECU, and the ECU controls and drives the gauges. There is no connection between the sensor and the dash. You'd have to reprogram the ECU to get a real variable oil pressure reading.
Regards,
Gordon
Old Jan 12, 2005 | 04:25 PM
Nemesis8's Avatar
Bigus Rotus
There is a way to do it, I read in the service manual about a port on the filter housing that excepts a device for the techs to check your pressure with a gauge. I also think the aftermarket Mazdaspeed gauge/pod has this very same connection part. I don't have my manual with me, so you might try looking it up, or waiting for someone to chime in here to add to this thread for you. Right guys??
Old Jan 12, 2005 | 04:31 PM
Gord96BRG's Avatar
No, he asked about converting the existing dash's "gauge" to a real oil pressure gauge, which can only be done by reprogramming the ECU. You're talking about adding a separate, external oil pressure gauge, which can be done as you said.
Regards,
Gordon
Old Jan 12, 2005 | 04:41 PM
Nemesis8's Avatar
Bigus Rotus
My bad - yep your right. It's still a lovely idiot gauge isn't it..
Old Jan 12, 2005 | 06:48 PM
army_rx8's Avatar
X-Sapper
not just lovly sexy as hell..if i can ever get a damn sensor attachment i'll have a nice sexy (defi bf) oil pressure and temp gauge to go along with my idiot gauges...hehe and the water temp will make it a nice double date:p
Old Jan 12, 2005 | 07:54 PM
Mat's Avatar
Mat
I think this is the thing that annoys me the most about my car (that says alot on how I absolutely love it).
I'm fine with having a car that consumes more oil than others, but I would have gladly spent an extra 100$ (considering the pricetag, it isn't a big deal at all) to not have to check the dipstick "each second fill-up".
Old Jan 12, 2005 | 08:06 PM
MI_FamilyMan's Avatar
Sold on Rotaries!
I'm no techie, but even if the gauge wasn't an "idiot" gauge, I think it would still only indicate the oil pressure, which doesn't necessarily translate into your actual oil level. So you would still be checking every second fill-up for safety's sake.
If I'm wrong, someone please correct me...
Old Jan 12, 2005 | 08:26 PM
Mat's Avatar
Mat
You might be right. In that case, I would have liked an oil level gauge Having a car that consumes a fluid that needs regular replenishment warrants a semi-acurate gauge, I think. I guess I'm being too dificult here...
Old Jan 12, 2005 | 08:46 PM
Nemesis8's Avatar
Bigus Rotus
We need an electronic level transducing dipstick :p
It would only work when the car is sitting level, warmed up, and then rested for awhile so that all the oil drains back to it's proper level to check :D
Old Jan 12, 2005 | 08:52 PM
Mat's Avatar
Mat
How about... about the same thing that's used for fuel gauge?
Old Jan 12, 2005 | 09:13 PM
bureau13's Avatar
How about an oil level idiot guage? It reads "full," then every second fill-up it drops to "low" whether it needs it or not? :D
jds
Old Jan 12, 2005 | 10:14 PM
Mr. Ed's rx-8's Avatar
no more 8
well for some reason today my oil light flashed on and then went off after a couple minutes. its been 2800 miles since my last oil change...kinda worries me but i'll just ask about it tomorrow when i go to find out if my warranty is voided!
Old Jan 12, 2005 | 11:14 PM
Mat's Avatar
Mat
OMG that rocks! I'll take a dozen.
Old Jan 12, 2005 | 11:19 PM
philodox's Avatar
Rangers Lead The Way!
I have disconnected my oil pressure gauge to put a true oil pressure gauge in, and guess what.. no CEL and the oil pressure meter on the dash still shows pressure
Old Jan 13, 2005 | 04:22 PM
army_rx8's Avatar
X-Sapper
^^ haha tha tis too funny:D
Old Jan 13, 2005 | 04:28 PM
Nemesis8's Avatar
Bigus Rotus
OK, please explain this one
Old Jan 13, 2005 | 05:10 PM
philodox's Avatar
I can't explain it.. I'm stumped myself.
Old Jan 13, 2005 | 06:03 PM
therm8's Avatar
Bummed, but bring on OU!
Maybe it's just a "The car is on" idiot gauge :D
mr. GrandGame
Sep 9, 2025 10:41 PM
9krpmrx8
Nov 5, 2015 11:45 PM
talonhart2
Aug 26, 2015 04:14 PM
foxyRoXy8
Aug 18, 2015 10:26 PM
digitalmonkey79
Jul 29, 2015 12:09 AM
