BLOWN8
01-08-2005, 02:45 PM
With the current mods: RE intake, UR pullies, CZ ecu stage 2, SR midpipe, mazdaspeed exhaust, and mazdaspeed ground wires, i am still looking for more power. I was going to go turbo but i think nitrous is a better route.
I Got the NX EFI wet kit, with all the acessories.
With the nitrous i didn't want to inject all of it into the motor at one shot, especially because i want to run up to a 80 shot, its to much stress on the motor. So i picked up the NX maximizer, which is new on the market and is a ecu for the NOS that is controlled by pc and injects nitrous progressively and different amounts in different gears, it also has a nitrous cut-off swith at a certain RPM for safety reasons. It can also monitor the A/F ratio and a bunch of other stuff too.
I've already started installing the kit, and it should be done in another weak. Im in the process of making a nitrous map and i don't want to run the map all the time because at the certain rpm when i the 80 shot is introduced the ignition is retarded 15 degrees and i don't want to drive with that when the nitrous is not being used. So im trying to figure out how to run the canzoomer to either run multi-maps (with stage 3) or be able to turn the CZ on/off with the nitrous.
I will keep everybody posted on my progress.
