New Saturn Sky = HOT!!
Old Jan 7, 2005 | 08:48 AM
c2k4-8's Avatar
I really like this car!
Attached Thumbnails New Saturn Sky = HOT!!-pv__020258__.jpg   New Saturn Sky = HOT!!-pv__020261__.jpg   New Saturn Sky = HOT!!-pv__020262__.jpg   New Saturn Sky = HOT!!-pv__022353__.jpg   New Saturn Sky = HOT!!-pv__022356__.jpg
Old Jan 7, 2005 | 08:49 AM
c2k4-8's Avatar
Some more photos.
Attached Thumbnails New Saturn Sky = HOT!!-pv__022359__.jpg   New Saturn Sky = HOT!!-pv__022363__.jpg
Old Jan 7, 2005 | 08:50 AM
Audioslave8's Avatar
reminds me of an Opel Speedster. I like...
Old Jan 7, 2005 | 08:52 AM
DreRX8's Avatar
I'm impressed by our version of the Vauxhall---What are its specs? Is it gonna cannabalize The Pontiac Solstice sales?
Old Jan 7, 2005 | 08:59 AM
SD-8's Avatar
This is from usatoday.com
"Sky two-seater roadster. The car, equipped with a 140-horsepower, 2.4-liter engine, signals a new design direction for Saturn, Lajdziak says. Other new models will adopt Sky's front end, which includes slanted headlights and a fender that juts out from the front.
The car goes on sale in early 2006 as a 2007 model and should be priced under $25,000. "
It looks a lot nicer than a $25,000 car, but it's still pre production, 140hp seems low, any one know how much the Lotus Elise is going to get?
Old Jan 7, 2005 | 09:04 AM
czr's Avatar
czr
RX8 RX8!
Looks good. I guess it competes with the Miata since the MR2 will die after this year.
Old Jan 7, 2005 | 09:06 AM
SHOWOFF's Avatar
NOT SEARCHING
Wow that is a HUGE change from the shitty *** Saturns of the past. I have always hated Saturns.
This I would consider.... did I just say that???
Old Jan 7, 2005 | 09:08 AM
dmp's Avatar
dmp
RX8 and a Truk....
I'd sell my rx8 for that car - IF it came w/ the SC'd engine from the Cobalt.
Old Jan 7, 2005 | 09:09 AM
Dlrosie's Avatar
GotZoom
Does look kind of cool. Hmmm....I would have two cars with the 2-tone red/black interior..........
Old Jan 7, 2005 | 09:19 AM
therm8's Avatar
Bummed, but bring on OU!
Saturn's website says it's going to have a 170hp 162lb-ft 2.4L ecotec.
Old Jan 7, 2005 | 09:21 AM
Gambit's Avatar
Screw gas mileage
I like the front of it, not really the back, and not the red dashboard either
Old Jan 7, 2005 | 09:27 AM
draco067's Avatar
Cap'n Limekitten says arr
the front (from the side) looks like the bastard child of a miata and a viper
Old Jan 7, 2005 | 09:30 AM
draco067's Avatar
Front engine, rear-wheel drive
2.4-liter, 16-valve, inline-4 Ecotec™ engine with Variable Valve Timing
170-horsepower; 162 ft. lbs. of torque1
5-speed manual transmission with short-throw shifter and self-adjusting clutch
Available electronically controlled 5-speed automatic transmission
4-wheel independent suspension with coil-over-Bilstein monotube shocks
18-inch flangeless alloy wheels equipped with Goodyear P245/45 performance tires
Hydraulic power-assisted rack-and-pinion steering
Hydroformed / stamped steel body structure with steel and aluminum chassis
Available torque-sensing limited slip differential
Old Jan 7, 2005 | 09:37 AM
draco067's Avatar
what the heck is a self-adjusting clutch?
Old Jan 7, 2005 | 09:43 AM
SHOWOFF's Avatar
NOT SEARCHING
On some cars with a cable driven clutch system you have to adjust the clutch cable every so often by lifting up on the pedal with your toes and then depressing the pedal to the floor repeatedly. This takes the slack out of the cable. With a hydraulic system you don't need to do this, the system will just use additional fluid out of the brake/clutch reservoir.
Correct me if I'm wrong, but this is what I had to do on some of my older cars.
Old Jan 7, 2005 | 09:51 AM
DreRX8's Avatar
This will sell--especially if its sold with an auto tranny for mainstreamers. I wonder how it will compare to the new Miata (especially with the upcoming SMG unit).
Old Jan 7, 2005 | 09:58 AM
BlueEyes's Avatar
hmmm, it looks an awful lot like the pontiac solstice that is coming out soon
probably the same damn car, you just get picnics and dent resistent doors with the saturn
Old Jan 7, 2005 | 10:14 AM
cgrx's Avatar
DRIVEN
it's begging for dual exhaust.
Old Jan 7, 2005 | 11:14 AM
murix's Avatar
That is the Saturn version of the Solstice built on the Kappa small car rwd platform. The car was originially displayed as the replacement for the VX220 a couple of years ago when they called it the Vaxhaul lightening. Expect the same specs as the Solstice, which means 2800lbs and a 2.4l 170hp ecotec when released.
The hot version will be the 2.2l 240hp supercharged ecotec motor that should follow in a year. This is the one expected to cost around $25k. Entry model should fall in around $19k.
It is a nice looking car and I am happy to see GM push for smaller cars.
Old Jan 7, 2005 | 11:18 AM
PaulieWalnuts's Avatar
Saturn finally has a winner.
CGRX, where the heck did you get that sig from? That's pretty funny.
Old Jan 7, 2005 | 12:24 PM
Steiner's Avatar
Let me pre-emtively apologize for hijacking the thread...but if you're in the "$25k and under roadster market" this bad boy would be my choice.
The Dodge Razor is the working title, but apparently there has been some recent litigation filed over the name. Whatever Daimler Chrysler decides to call it, I'm expecting it to have the turbo charged, 230hp (actually more like 265hp) , 2.4L turbo found in the '04 and '05 SRT-4. At less than 3,000lbs, with RWD and an incredible stout and tunable platform...watch out! The Razor would be a terror both on the track, the twisties, the drag strip, the freeway, the gas pump and on your insurance premiums. I imagine this car would also be relatively inexpensive for DC to produce if they used one of the existing Mercedes RWD compact platforms. I pray to baby Jesus himself they make this car. Until now it seems most roadsters (MR2, Miata, etc) are a bit underpowered for traditional "car guy".
Old Jan 7, 2005 | 12:33 PM
rotten42's Avatar
Mentalhealth is overrated
Well, it should go like stink...good thing becuase a car that ugly shouldn't stick around spreading its ugly germs to other cars ....yuk!
Old Jan 7, 2005 | 12:37 PM
Steiner's Avatar
Ugly?!?! If I was a car I'd hit it. Who knows what the production model will look like anyways though? Those huge rims are over the top. If it's sold as a Chrysler I'm sure there will eventually be a convertible trim too. Just think about the power...
mmmmmmm....turbo charged...very tunable....psssssshhhhhhhhh pssshhhhhhhhh!
Old Jan 7, 2005 | 12:41 PM
czr's Avatar
czr
RX8 RX8!
Maybe it's because of the color... very 350z esq. (bleh). Maybe it will look better in black or dodge red.
But that thing would be a steal at under $25k and be a formidable foe of the S2K maybe even the srt crossfire if you tune it.
Old Jan 7, 2005 | 03:25 PM
mikeb's Avatar
100% Italian
I saw this car at the la auto show years ago
its still a saturn
