Petrus
01-01-2005, 07:15 AM
Has anyone experienced flywheel balancing problems after installing an aftermarket one? Iīm about to install a aftermarket lightweight flywheel and have my eyes on several ones. I find the design of all flywheels to be very different, material, one piece flywheel or several pieces, where the weight is located etc...
Here are my thoughts:
MS leightweight flywheel:
I like the look of this one. Itīs a one piece leightweight flywheel wich theoreticly minimizes the chance of unbalancing. Looking at the design I find that most of the weight is located at the center and the drilled holes at the outside minimizes the weight and G-force at very outer end. The MS flywheel is a bit heavier than others (and itīs not made of aluminium), but the design of it (most of the weight located at the center) should compensate for that. I actually believe that this is prefered if you compare it to one that has the exact same weight but more evenly distributed over the surfase. I donīt think one should stare oneself blind at the total weight only but rather where the weight is located.
Racing Beat
Looks like a 4 pice wheel... Which SHOULD mean that the chances of inbalance increases. I belive RB makes good quality products but a one piece wheel SHOULD minimize those chances. Itīs lighter than the MS one but the weightdistibution seems backwards. Judging by the picture it looks as if itīs heavier at the outer edge than the MS one and its lightest part is at the centre. More rotating mass and higher g-force...
SR Motorsports
The lightest of the 3... Nice design and painted... :eek: :D Reminds alot of the RB one designwise. Not much to add here...
Those of you who has a aftermarket lightweight flywheel installed: Have any of you done a correct balancecheck of the wheel. Inbalance would put an enormous stress on the engine and reducing its longlivety. Is it safer to go with the more expensive MS onepiece fw that any of the others? Whatīs your experience?
Happy new rotaryear!
Racing Beat
SR Motorsports
