Catch-can install
Old Dec 31, 2004 | 01:32 PM
NoTears316's Avatar
Shock and Awe
Catch-can install
OK, just installed the catch can. I found a description of the GReddy catch can and this is what it says...
"A catch tank (or can) works just like a crankcase vent filter. It will bypass the connection between the crankcase and the air induction intake track. This will relieve pressure place against the valve train under engine load. But unlike a crankcase vent filter, the oil used by the valve train will not drip onto adjacent engine components. The oil catch tank will ‘catch’ the oil and moisture in the blow-by gas that cause carbon and sludge build-up in the intake system and the engine. This will keep your engine compartment clean, your performance maximized, and give your engine that custom look."
I agree with everything after the last comma in that paragraph.... give your engine that custom look. I'm not noticing anything else. Sure looks pretty though.
Old Dec 31, 2004 | 04:09 PM
theCATALYST's Avatar
In darkness I sleep.
Maybe a newb question, but how bad was the install? Also will Mazda warrenty have any issues with it? I cannot see why they would, but I thought I should ask?
Old Dec 31, 2004 | 04:15 PM
NoTears316's Avatar
Shock and Awe
Install wasn't too bad, didn't mount where I originally wanted it, but due to the size (height) thats the only place it would fit properly. No warranty issues, already checked.
Old Dec 31, 2004 | 04:43 PM
army_rx8's Avatar
X-Sapper
where did you want to put it originaly...looks pretty sweet right where it is IMO
galognu
Rotary Swaps
138
Nov 16, 2020 05:20 AM
Zube6115
Sep 30, 2015 12:57 PM
Learners_Permit
Sep 27, 2015 07:38 PM
Evan Gray
Sep 26, 2015 12:30 PM
