professional advice pls
friend selling his RAYS GRAM LIGHTS 57F Pro 19*9.5 (front) 19*10.5 (rear) will it fit on my 8? no tires
if not wat modification do i need to do on the side guard?
will that size hv any effect while turning? (3 point turn?)
wat size tires shell i use?
thx for your help in advance :o
need to know the offsets and also if you're dropped or not..
you could roll the fenders but even that might not give you enough room..those are WIDE sizes...9.5 is way too much for the front i think..
Depend on your offsets. Like XeRo said, need to know if you're planning to lower the car, and if so, by how much? Need to know the Rim Offsets. And yes, you will have to roll the fenders. Not considering offset or anything else, here are the tires sizes you should go with:
Front: 255/35/19
Rear: 285/30/19
Front: 255/35/19
Rear: 285/30/19
Michael Bryant
Oct 12, 2015 03:07 PM
Evan Gray
Sep 26, 2015 12:30 PM
Touge
Canada Forum
Sep 23, 2015 10:51 PM
