aggietiff28
12-04-2004, 04:00 PM
Ok, this is the second time since I got the "M" flash that my service engine light has come on. The first time I took it in and and the service tech said that it just went off on its own right before he tried to figure out what was wrong. This time it came on after I had let the car idle for awhile (~35 minutes outside my office because I had planned to run in and out and ended up staying awhile). It still hasn't gone off after a day and I have checked the oil, gotten gas and tightened the lid, etc. Is there anything else it could be? I just really don't want to take it in to the dealer and it be "nothing" again.
zoom44
12-04-2004, 04:05 PM
probably a temporary overtemp situation or a misfire. but to be sure you would have to have soemone tell you the code it stored. the service tech should have been able to pull a code the last time. the light should go out after a few more on off cycles without what ever the problem was re occuring. if turns into a FLASHING CEL get into service a soon as possible. not likely to happen tho.
snap-on
12-04-2004, 07:59 PM
CEL information is stored in the PCM for ..I think 100 key cycles.
I serious doubt it was a P0455 (loose filler cap) since the new PBE system checks the Evap after the car has been shut off.
aggietiff28
12-04-2004, 08:12 PM
Well, thanks guys...I have been all over town today running erands. Have started and stopped the car at least a dozen times. Light is still on. Nothing weird about the car that I can tell. Not running hot, etc. Looks like I will be seeing the dealer this week.
