check tire pressure
check tire pressure
OK I know this is probably a waste of space. but... we had 3 customers in 3 weeks that came in because there tire pressure light was on.(that was the only reason they came in) all 3 had low tire pressure. this customers wasted there time going to the dealer just because of the light. if the light comes on just take a minute and check your tire pressure. it will save you the time and headache of taking time off work just to take it to your dealer. I don't think the people were club members.
Alright, I'm giving out a laugh at my expense...
The day I bought the car, the TPMS light was on and I thought it was the check engine light (first car with TPMS). I thought the light was supposed to look like a rotary engine. That night when I read the manual I felt like a dumbass. :D
My TPMS light kept acting up. When the tires were cold it was on, then it would go out after a few miles. I checked pressures. All was well except for a left rear that was a little low. Couple of weeks later, it happened again, but the pressures were virtually the same. After a few weeks, I realized that the left rear was low again. Hmm
Two months later and a just a couple of days ago, I walk to my parked car to discover a screw that was jammed into the edge of the tire. Problem solved. F@#k
I find TPMS is a subtle reminder that I haven't checked the tyre pressures as often as I should. Nice feature especially when not carrying a spare wheel. And especially in this extremely cold weather in the Houston area!!!! Must remember to change out of my shorts and T shirt in the next month or so!
actually the service bulletin states that once the car reaches 16 mph the light should go out. Google rx-8 tire pressure and click the pdf file on the first page.
No worries, Hot to Cold equal less pressure within the wheel. Just do a burnout and the light will for sure go out!!!! hahahah
Cheers
J
Cheers
J
Cheers
J
Cheers
J
Cheers
J
Cheers
J
wow you guys really have some issues with people trying to help out. The service Bulletin no 02-004/04 was the only reference I had and it stated that "The TPMS system will turn the warning lamp off after the vehicle is driven over 25 KM/h (16 MPH)
So don't take it personally if the information is no longer current. And By the way MAZFUR your attiude blows I suggest you grow up. If you don't like the post I made then don't respond like a teenager would.
I am just trying to help.
I'm not gonna rag on someone for trying to help, even if the info isn't correct or up-to-date..........only if it's been pointed out that they are wrong and continue to provide bad info and are stubborn about it. Okay?
So.......I added this little portion tonight(11/7/07) because I wanted to see if you even would acknowledge that the fact that you were wrong, so who's all grown up now? Hmmmm?
drebbrnator
Dec 27, 2018 07:02 PM
05TiGr8Lady
Aug 27, 2015 07:31 PM
