just for Jspec
just for Jspec
i find this new product at the Rmagic page, its a new harnes for the..........(in spainish "bobinas de encendido") where gos the coil cable separete from the car to protectet from the hit
a picture is beter of a spainish explein no jejejeje
Looks like the picture on this page (babelfish assisted):
http://babelfish.altavista.com/babel....html&lp=ja_en
Looks like something about shifting the coils so they are cooler and improving the spark.
Well I suppose I should be happy that he started ths thread for me.... saves me some work.
NFS is talking about the new coil and plug wire setup that I mentioned about a week ago. RMagic has two kits... the coil, wire and splitfire plug set and the coil relocation kit which also has room for mounting the RMagic grounding kit as well. If you get the relocation kit, it can also be used with stock coils. The upgraded coils and wires are suppose to help improve ignition under heavy loads and high rpms. If I remember correctly it had been said that the coils that come on the 8 stock are just barely adequate up to 8's redline...
http://www.rmagic.net/new_item/new09.html
