Front sway bars questions
Old Nov 15, 2004 | 08:12 AM
clyde's Avatar
www.TeamWTF.org
After a not too in-depth look, I've found a few front (not interested in rear bars) sway bar specs (please correct if anything is wrong or add any bars that I'm missing):
Stock: 27.0mm
Mazdaspeed: 27.2mm
Racing Beat: 32.0mm
Tanabe: 30.4mm
Does anyone know the answers to the following questions?
TIA!
Old Nov 15, 2004 | 01:20 PM
alnielsen's Avatar
I have never seen a tubular sway bar. The only ones I know of are solid bars. As far as adjustable bars, Rick Shaw is the only one I have seen to have a adjustable front bar. They offer a adjustable front and rear. They have 3 different positions/holes for adjustibility. This is the combonation I will be buying when I start my mods. There is another company that offers an adustable rear bar. I don't remember who it was at this time. My 1st gen RX7 had a sliding adjustable rear bar by Suspension Techniques.
Old Nov 15, 2004 | 02:03 PM
Z00M RX8's Avatar
Both of the stock front and rear sway bars on the RX-8 are hollow. Racing Beat's site has the specifics.
http://www.racingbeat.com/FRmazda4.htm
Old Nov 15, 2004 | 03:02 PM
Ophitoxaemia's Avatar
dizzy snake pilot
note: you can calulate the rate of a hollow bar by first calculating the rate of the bar if it was solid, and subtracting the rate of a bar that is the diameter of the hole.
since the stiffness is related to the fourth power of the radius, hollow bars are a very effective way of reducing weight while increasing the stiffness of the car.
the other point this makes is that if the bar is hollow, you can tell nothing about the rate from just the outside diameter.
james
Billy Marcial
Mar 1, 2018 06:50 AM
MsKingRotary
Apr 23, 2016 05:45 PM
Solidtrance
22
Sep 4, 2015 12:47 PM
MolecularConcept
Jul 26, 2015 09:09 PM
AussieGray
Jul 16, 2015 03:58 AM
