TyrellCorpNexus8
11-11-2004, 01:13 AM
I thought this was important enough to start a new thread for the people who intend to change their own manual trans and differential oil and who plan on getting new crush washers instead of reusing the old ones. Apparently, there has been a lot of confusion on the other gear oil threads regarding the part numbers.
In one of the most useful and most cited resources, forum member "jdl" posted pictures of all the parts, torque specs for the four bolts (transmission fill and drain bolts & differential fill and drain bolts), trans & differential oil capacities, and crush washer part numbers. The URL is http://www.5cats.org/rx8/trans_diff_refill/.
"jdl" was correct in stating that the transmission fill and drain washers are identical (they have one part number). However, he listed only one part number for the differential washers, suggesting that the differential fill and drain washers are also identical to each other, which is incorrect. THE DIFFERENTIAL FILL AND DRAIN WASHERS ARE IN FACT DIFFERENT AND HAVE DIFFERENT PART NUMBERS. Even the pictures on jdl's website show clearly that the differential fill washer is COPPER whereas the drain washer is not.
In the "Royal Purple Tranny/Diff Fluid Swap" thread started by forum member "brillo," another forum member, "rev-2-9k," correctly noted that the differential fill and drain washers are different and have different part numbers. However, he listed an incorrect part number (probably an inadvertent mistake).
It seems many forum members have just bought whatever crush washer and reported no leakage and everything fine. But if you wish to stick to the details, here they are:
* manual transmission fill crush washer: Y601-17-361; silver in appearance
* manual transmission drain crush washer: Y601-17-361; silver in appearance
note: the manual trans fill and drain crush washers are one and the same
* differential fill crush washer: 9956-21-800; COPPER in appearance
* differential drain crush washer: 9956-41-800; silver in appearance
note: the copper differential fill crush washer is about 2.5 to 3 times more expensive than the differential drain crush washer.
note: the manual transmission crush washers cost slightly less than the differential drain crush washer.
BTW, you can use the prices on Rosenthal Mazda's website as a rough guide. The URL is http://www.finishlineperformance.com/rx8/rx8_maintenance.html. The couple of local dealerships I called had significantly higher prices than Rosenthal's but I was able to negotiate the prices down a bit by citing Rosenthal's prices. Please note that Rosenthal also fails to differentiate between the differential fill and drain washers, stating only the price for the drain washer at $1.13 each. Their price for the manual transmission fill/drain washer is $0.78 each.
The parts guy at a local dealership was the first person I talked to who knew what is going on with the washers. He also explained to me how the part numbering system works: the middle two-digit number describes the material; the last three-digit number describes the size. So the 17 from the trans washers and the 41 from the differential drain washer indicate they are made of different material even though they are both silver? He wasn't sure.
I hope this helps.
I hope this helps.
