quack_p
11-10-2004, 11:47 PM
Can anyone recommend a good cordless vac? I need a small one I can use in my apartment's parking lot.
View Full Version : Cordless vacuum? quack_p 11-10-2004, 11:47 PM Can anyone recommend a good cordless vac? I need a small one I can use in my apartment's parking lot. DOMINION 11-11-2004, 04:03 AM Dirt Devil? quack_p 11-11-2004, 10:45 AM This one (http://www.filterstream.com/V2100pf.htm) seems pretty good. What do you guys think? XDEEDUBBX 11-11-2004, 11:00 AM a mini broom and mini dust pan...take it anywhere and a 1/4 of the price! markd 11-11-2004, 12:44 PM You could also consider getting a power adapter for your cigarette lighter so you can plug appliances into it; then just buy a regular handheld mini vac. You can get the adapters at Wal-Mart for like $10. Nubo 11-11-2004, 03:28 PM Black and Decker made (probably still does) a handheld car-vac that works fine. It's not cordless, but uses 12V from the cig lighter. I don't think it makes sense to deal with the cost, weight and other issues of a cordless solution when power is available from the vehicle. Genesis 11-17-2004, 10:04 AM Black and Decker made (probably still does) a handheld car-vac that works fine. It's not cordless, but uses 12V from the cig lighter. I don't think it makes sense to deal with the cost, weight and other issues of a cordless solution when power is available from the vehicle. I've got the B&D car-vac and it's great. It has a 5m cord to get to all areas of your 8 and has two attachments for those narrow needs around the seats :) Agreed with Nubo, get the cig lighter powered versions...the cordless ones are ok too, but they are more expensive and if you have to do some heavy vacuuming then they lose juice fast. |
