View Full Version : My Car dies while driving
KYRX8
11-08-2004, 11:51 AM
Alright, ive searched and only found one thread on this and it wandered way off topic.
This happened to me 3 times yesterday and had never happened before. I was driving in town at city speeds, not to fast, and when i would put the car in nuetral and the car would die, it would always restart but it shouldnt die at all. I watched it die the 3rd time and when it did it the tach needle drop from 6k to 0 quick and the car died. I watched the needle the rest of the day while coasting to a stop and noticed everytime i hit N the needle would go damn near all the way to zero then resume idle speed.
Anyone had this happen to them or heard of a problem/solution..???
I was running 89 octane and it was a lot warmer yesterday then it had been the last few days... Is it possible that this was a freak thing caused by the different gas and warmer weather???? Im just throwing things out here trying to figure it out? Any guess'
czr
11-08-2004, 12:26 PM
AT or MT for people who might know what this is. I've never experienced that but either way I'd take it to the dealer. That could be dangerous.
menace1227
11-08-2004, 12:30 PM
Go to the dealer pronto. Don't risk it man!
KYRX8
11-08-2004, 12:37 PM
im gonna try to get up there this afternoon
slllygrl10
11-08-2004, 12:47 PM
wow thats weird. I have AT and I normally have it on N when the car is not moving
KYRX8
11-08-2004, 12:52 PM
mines the 6 spd and i dont know what possessed me to put it in N like that but its got me worried now
zoom44
11-08-2004, 03:36 PM
it sounds like a confused PCM to me. there are 2 different fuel maps used during decleration. 1 for when it is decelerating in gear and one for when you are decelrating and down shifting( i may have something wrong there- i dont feel like i said it correctly). we also know that the car also cuts some of the fuel on decelration and when it gets to idle the firing order(leading/trailing) switches. it sounds like your car is confused about what you are doing. now i have done a 6th gear drop into neutral and coast down a hill several times- it's against the law, it's dangerous yadda yadda- and not had this occur. have you done any mods to your car that would involve electrical connections. done anything with the grounds? have you done this when the cruise control was on? how much fuel did you have?
someone in that other thread said Coasting down hill in neutral isnt going to hurt your motor AT ALL. your in neutral..the engine isnt turning the tranny. OR i should say the tranny isnt turnning the engine. Oil pressure would be low cause the rpm is probubly down near 800rpm. The engine dones't even know your coasting. all it knows is that its idling as if it was idling in your driveway.
Justin
i know its old but i wanted to point out that the above statement is false and the car sure does know you are coasting- it know the throttle position, speed, rpms and gear selection- and changes which fuel map it is using and plug firing order. its also going from open loop to closed loop.
KYRX8
11-08-2004, 03:53 PM
i was coasting to a stop light 2 out of the 3 times and going around a round a bout the 3rd time when it happened (i was just holding the clutch in that time).
I was at the dealership today and they plugged it up and captured a funny graph when the revs are coming down.. they had never seen this before. Anyway, he recorded it and is going to send it off somewhere to let them analyze it. in the meantime he updated it with a new flash they just released last week and we just get to sit tight and see what the car does or what the tech guys say.
It happened 3x yesterday afternoon but none last night or today
zoom44
11-08-2004, 04:14 PM
there was no new flash released last week. it was just an update to the tsb with the same flash. but at least this time it seems every tech has heard about it.
Sea Ray
11-08-2004, 04:22 PM
It must be one of those yellow car things :)
It would interesting to hear what he comes up with as I tend to put it in neutral like that also.
KYRX8
11-08-2004, 04:55 PM
he might have meant update.. he was working on my borhters car and mine at the same time so i could have heard wrong.
Yea, im gonna run up there after work to look at my brothers car and ask him if he found out anything about mine. I told him to take his time with mine because im fine as long as the car runs.
snap-on
11-08-2004, 07:13 PM
The problem here is the PCM doesn't know you are in neutral..Have the dealer check the pid using the WDS and see if the "ingear" value changes as you move the shifter.
The car will go to a specific map in neutral and another when you are driving.
I've seen this one two different occaisions now.
KYRX8
11-09-2004, 07:49 AM
ill do that, thanks
Mr M
11-09-2004, 10:05 AM
Faulty clutch switch.
If it is not the clutch switch, then it is the neutral switch in the transmission.
Both are easy to access and test.
KYRX8
11-09-2004, 10:17 AM
yea, i called my dealer and they are going to look at it this week and take care of the problem. Apparently that wds box is a pretty wicked little box that tells you all sorts of cool diagnostic stuff
zoom44
11-09-2004, 02:03 PM
cool so i was on the right track asking about electrical things- im getting better at this:)
KYRX8
11-09-2004, 02:21 PM
yep, the part will be thursday or friday and then they will replace it
staticlag
11-09-2004, 02:54 PM
I coast in neutral all the time. It is really bad? I will be on the top of a hill, with light at the bottom and just put it in neutral and coast to the light.
Spyder_doo
11-15-2004, 03:15 PM
Funny my yellow 8 did the same thing for about 2 weeks. My problem was the vacuum lines going to my new K&N intake pipe were not a tight fit. I just replaced the hose with a thicker walled and tighter fitting one. No more problems.
Jamie
Mugatu
11-15-2004, 03:27 PM
Wait a minute, you're saying that you put the car into neutral while your driving at speeds over 40mph?
I dont understand why you wouldn't have the car in gear at all times except when you come to a complete stop. Not quite sure the driver should be driving in a car where it is not engaged in a gear at highway speeds. I hope that it isn't for some reason like trying to save on gas mileage or some other reason like that....
I am not knocking the fact that your car is stalling, just not sure if I am understanding you right.
KYRX8
11-15-2004, 03:29 PM
when im slowing down to come to a stop the car does that in nuetral. I dont just get up to speed and coast, its just when im coming to a complete stop. Its an old pizza delivery habit i have from delivering pizza for 5 years.
RotaryNoob
11-15-2004, 06:24 PM
I do the same thing most of the time if when I have lots of room. I figure its cheaper to replace the brakes then it is to replace the clutch. I downshift if I need to stop fast.
I know I know, rev match the downshifts... easier said then done. For some reason I can't get used to how fast the revs drop in this beast. Maybe its the drive by wire...
xxdevilzeroxx
11-18-2004, 12:22 PM
hmm i was testing my intake kit that im making for my car, i have 2 other cars with me, a AT and MT, both died just like you said, the problem was the intake, i had a regular cone style filter in the car, when we changed the intake filter to a cone with a funnel inside everything was okay..........
Mr M
11-18-2004, 04:39 PM
wander......wander........wander.......... :rolleyes:
