Help with front turn signals
Old Nov 7, 2004 | 05:45 PM
EatInTheAte's Avatar
Rxhausted
Can someone give me some help on how to remove the orange front turn signal bulbs? Do I have to remove the entire headlight lens or do I go through the wheel well like I did with the clear corner lenses? Thanks very much,
Old Nov 7, 2004 | 06:45 PM
Omicron's Avatar
You bet. For the clear corners, check out this thread. It's got great directions in it on how to remove and replace them.
As for the amber bulbs in the front turn signals, no need to remove the headlight assembly. To access them, you have to remove the fuse box cover in the engine compartment on the driver's side to access that bulb, and the ECU cover on the passenger side to access that bulb. And even then, it's a bitch to reach them, but have patience and you WILL get it, just as I did. I replaced my turn signal bulbs with "stealth" chrome bulbs.
Hope this helps! :D
Old Nov 8, 2004 | 03:06 PM
MELRX8's Avatar
"RX-8 my stress reliever"
Hope this helps! :D
Omicron: Do you find the Stealth Bulbs bright enough, particularly on bright days?
Old Nov 8, 2004 | 05:08 PM
Rxhausted
Thumbs up
I tried doing it the same way I installed my JDM side markers(behind the wheel) and I found this way to be much easier. Thanks for the help though
-Jim
Old Nov 8, 2004 | 07:29 PM
Omicron's Avatar
They're not as bright as OEM bulbs, but they're ok.
Old Nov 8, 2004 | 07:30 PM
Omicron's Avatar
-Jim
Actually, you're right. I was misremembering how I installed the turn signal bulbs. I did indeed have to access them from the wheel well. Sorry for the confusion!
TeslaMSI
Dec 10, 2015 01:10 AM
CARBONRX-8
Aug 23, 2015 09:52 PM
